LG 42LC2D Power Supply Issue
  • slidr
    • May 2015
    • 8
    Does anyone have the schematic for PSU: 6709900017A (YP4201 06.02.15 Rev. 1.3)?
    I replaced 4 10V 2200MF capacitors, and now when plugged in, it clicks once while illuminating the green LED on the front of the TV, then immediately clicking again, turning the LED off. I then have to leave the TV unplugged for at least 5-10 mins before I plug it in, in order for it to do it again. If I plug it back in right away, nothing happens...no green LED, no click.
    While plugged in, I get the following readings...
    At P201
    • AC pin = 2.25v
    • POW pin = .01v
    • 5V pin = 5v
    • ERR pin = 4.98v
    • 5V pin = 5v
    • DIM pin = 4.98v
    • 6V pin = .01v
    • 3.4 O/F pin = 0.14v
    At P202
    • 19V pin = 19.28v (and drops at rate of 0.01v/sec)
    • 19V pin = 19.24v (and drops at rate of 0.01v/sec)
    • 6V pin = 0v
    • 3.4V pin = 0v
    • 12V pin = .37v (and drops at a rate of 0.02v/sec)
    I'm assuming that I'm not a candidate for the AC Detect optocoupler fix since I see the 5v?
    Thanks.
  • joeytino
    • Dec 2011
    Re: LG 42LC2D Power Supply Issue
    I saw your post and wondered if you ever found a schematic. I have the same TV, but in my case I have nothing on the 3.4 volt outputs. It seems these boards have a pretty high failure rate and you would think there would be more info on them out there.
    Best regards.
    • saddle_au
      Waste Warrior
      • 121
      I have had the same problem in the 32 inch version and it turned out to be the cable between the power supply and the motherboard. The connections were bad/intermittent.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Best regards.
        Service manual may help you.
        http://www.umlib.com/brand/LG/catego...ocument/683229
        • joeytino
          • Dec 2011
          Originally posted by dick_barton
          Thanks for the link, but...
          You would think that would be the go to place but LG frustratingly left the schematic for the power supply out of the service manual and simply tells you to replace it. Understandable for in the field service, but when you are able to fix it, that is not much help.
          • NJ1Q
            • Sep 2019
            • 4
            I had a similar issue. A number of the p/s caps were "pregnant." I replaced them with higher voltage values, and the TV has worked fine for years. But, it started acting up again. A couple of clicks after power up, and then nothing. None of the caps look bad.
            Now, I do not have the STBY 5 volts present. There was mention of the AC optocoupler issue and the (lack) of 5 volts. I cannot find that issue mentioned anywhere else. Nor can I find a schematic for the p/s.
            Could someone enlighten me on the issue? I see there are at least four (4) optocouplers. But, I cannot make out the part numbers very well.
            Thanks!
            Rather frsutrating!
              Lets see good clear straight shot pictures of the whole top and bottom side of YOUR power supply board.
              • NJ1Q
                • Sep 2019
                • 4
                Sorry about that. Same P/S, but for a LG 42LB1DRA.
                No 5 V with AC power. But, when first applying AC power, there is 5 V on P201 but for just a split second. Nothing afterwards.
                Thanks.
                  So do you get the Voltages if you power the board by itself without other boards connected?
                  • NJ1Q
                    • Sep 2019
                    • 4
                    That I didn't as yet try. But I can do that.
                    • NJ1Q
                      • Sep 2019
                      • 4
                      I disconnected all the connections from the power supply board. Oddly enough, the only voltage present when AC power is supplied is the 5 V. There are no other voltages present.
                      • BMARo
                        • Jan 2022
                        • 3
                        • Romania
                        I have this LG TV. The PSU is fine, but because HDMI port is not functional, I want to use another universal motherboard for this TV, using this PSU for display lamps. Can somebody tell me what pins I need to connect to power On this PSU ?
                        The PSU have this pins on connector P201:
                        1. AC
                        2. POW
                        3. 5V
                        4. GND
                        5. INV
                        6. ERR
                        7. Bri
                        8. 5V
                        9. GND
                        10. DIM
                        11. 6V
                        12. GND
                        13. 3.4 O/F
                        Thankyou!
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          I would say pow to ground or around 3v depending on what state it is in plugged in.
                          • BMARo
                            • Jan 2022
                            • 3
                            • Romania
                            Thanks, but INV ? It not necessary ?
                              • 12269
                              • U.S.
                              It is not clear what you are trying to do, can you go into detail?
                              • BMARo
                                • Jan 2022
                                • 3
                                • Romania
                                Yes.
                                I want to remove the original motherboard, and replace it with this universal one. https://*******/3s8Pvxl
                                But because its power source cannot power the CCFL lamps, I want to keep the original power source board to power the display, and start this power source board through a relay controlled by the universal board. Or two relays if necessary. Basically those relays should open/close the contact between POW with GND or 3V and between INV with GND or 3V. But I don't know what contacts the relay should make for the power source to start and the display to work. That is my question. What contacts should I make on this source for it to start and operate normally without the original TV motherboard?
                                Thankyou
                                  • 12269
                                  • U.S.
                                  Ok I see, maybe this will help, there's quite a few videos about the subject on youtube: https://www.youtube.com/watch?v=QzXpp6DyimA
                                  • Soulzink
                                    Samsug washing machine. Power supply DC41-00189a board issue
                                    by Soulzink
                                    I am trying to fix a samsung washinmachine power supply main board.
                                    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                    The power supply board reference is the following: DC41-00189a
                                    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                    04-19-2025, 06:26 AM
                                  • KYBOSH
                                    Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                                    by KYBOSH
                                    I have a floodlight-security camera that recently died on me.
                                    its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                                    Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                                    07-01-2024, 06:54 AM
                                  • Cookybaby
                                    Samsung UN60ES6500FXZA Power Supply Issue
                                    by Cookybaby
                                    Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                    I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                    Make: Samsung
                                    Model: UN60ES6500FXZA
                                    Power Supply P/N: BN44-00525A
                                    Symptoms: The TV was...
                                    08-20-2023, 12:26 PM
                                  • lp20th
                                    Samsung Plasma TV Power Supply Issue
                                    by lp20th
                                    I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                    11-28-2023, 10:28 AM
