ns-pdp50hd-09 Blinking Codes?
  • dhack61
    • Aug 2010
    • 33
    Anybody out there have a list of the blink codes and what they mean.
    I picked up a ns-pdp50hd-09 gonna tear into it this weekend. Right now all I can tell you is when plugged in it starts to light up the screen, then goes off. LED is blinking continuously. Code chart, Service manual would be helpful.
  • dhack61
    • Aug 2010
    • 33
    Re: Insignia ns-pdp50hd-09 Blinking Codes?
    OK Started to look into this set.
    Voltage Tests on Y main board Samsung BN96-07132A (LJ92-01535A)
    Spec ............ Actual
    Va 57 57
    Vs 204 204
    Ve 96 95
    Vsc -195 -50
    Have Standby power but no change when power button depressed. The flashing LED's I saw are not from the power board but are on the Samsung LJ92-01531D Main Logic CTRL Board. 3 LED's come on when set plugged in. one in the center goes out and the other 2 flash continuously. Still Looking for Help.
    • KevinCro
      • May 2014
      • 104
      Re: ns-pdp50hd-09 Blinking Codes?
      I had one of these. I believe the logic board lights just mean that the main board is sending signals to it. My advice would be to pull the top buffer board and see if you can get the bottom half of the screen to work. If that doesn't work then reinstall the top buffer and remove the bottom. If removing either board causes change then the removed board is bad. You can test these using a multimeter.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • pc_okay
        LENOVO IdeaPad 3-15ALC6 - 82KU (board NM-D521) blinking continuously 0.5A
        by pc_okay
        Hello friends,
        I have this laptop AMD Platform starting & not posting, fan spinning.
        When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
        If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
        I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
        CPU and his area heat, maybe the cpu is dead?
        10-21-2024, 10:23 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
