AKAI AKFL3254HF1 dead
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello, i have this AKAI LCD TV that was burned. I found that mosfet was open and it burned. The bridge rectifier was shorted in AC, shorted 3 x1 Ohm resistor and 4 x 20 Ohm SMD resistor. I replace them and TV show red light (like stand by light) but it wont respond to POWER button.
    After some minutes i noticed smell, i check it and found that 3 x 1 Ohm was burned (shorted, 0 Ohm).
    I must say that i put different bridge rectifier instead RS405M i use KBU 810, but i do n ot think this will make problem.
    ...the quieter you become the more you are able to hear...
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: AKAI AKFL3254HF1 dead
    Does anyone have schematic of this?
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      i find that i have 5V standby and i think main board wont turn on main 12V/24V
      Any ideas?
      • newtothis
        • Mar 2013
        • 1556
        • england
        What voltage are you getting at the PS_ON pin when attempting to power the set?
        • ammarben
          • May 2013
          • 63
          • algeria
          start power supply alone ps-on to 5v with 1k resistor
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            Is this bad steper coil of what ever it is called?
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              i have 4.28V all the time, and when i press POWER it stay at 4.28V
              • newtothis
                • Mar 2013
                • 1556
                • england
                Is that the board in its current state?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  no, i replace resistor that was burned.
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Just a resistor??
                    There are multiple missing components and components that have not been soldered in.
                    There is also a pad torn up
                    If that is that state of the board how do you expect it to work?
                      Those resistors are connected in parallel so the resistance will be very low, so did you check those 3 large resistors off the board, they usually go open circuit when too much current flow through them, they are for the Source resistor for the power MOSFET for the PFC Voltage booster circuit. Did you check to see if the MOSFET has Source to Drain shorted out. Without working PFC Voltage booster circuit, you will not have 12V/24V due to the circuit needs the boosted Voltage to operate. More likely the PFC IC controller is also damaged.
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        Just a resistor??
                        no i just use the old picture, this in new one
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          In first when i got the TV those 3 resistor wehe dead, MOSFET dead (shorted), i repalce 3 resistor with new one (1 ohm) and new MOSFET MDF13N50.
                          Now i take these new resistor away from board and they still show 1ohm resist but look on the photo what happen to them.
                          Can you point me to PFC IC on the board? how to check it?
                            When that PFC MOSFET is shorted out, it should have blown the main fuse.
                            No need to check the PFC IC (bottom right 8-PIN SMD IC closed to the main fuse), just replace it, and also need to check the Gate drive resistor/diode/transistor.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              hello, i replace PFC IC. When i put power to TV it change for red (stand by) to blue but then my dimm test bulb start glow and then u pull the plug. Is this normally when TV start?
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                i try to disconnect invertor and i still have bulb light after i turn on TV. Please any suggestion?
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  is it safe tu keep runing tv when bulb test glow? Please help
                                  • ammarben
                                    • May 2013
                                    • 63
                                    • algeria
                                    NO you have short circuit
                                    • BalkanBoy
                                      Dead Razer Blade 14 2022, shorted CPU?
                                      by BalkanBoy
                                      today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                      Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                      I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                      Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                      I removed coil and injected 0.7V, it draw around...
                                      09-27-2024, 12:44 PM
                                    • Andreasbest
                                      Lenovo P50 dead with burned motherboard
                                      by Andreasbest
                                      Hello.
                                      I received a P50 in very good shape that is dead and smelled burned board when on power supply.
                                      I strip it and found a heavily burned area, there should be some cap but now are smoke.
                                      Not sure where the one copper trace stops and starts the next, they seem mixed probably due to heat, this is my main problem as i'm not sure where should i solder what, so any help is appreciated.
                                      Schematics & boardview here
                                      Pictures os the affected area attached below.
                                      Not sure if it can be saved but i'll give it a try.
                                      Thank you in advance!...
                                      03-26-2024, 06:22 AM
                                    • FeerBaron
                                      PNY XLR8 RTX 3090 dead. Is this PEX shorted? Am I cooked?
                                      by FeerBaron
                                      I rebooted my computer and suddenly it didn't detect. It was nvlinked to another card that works. Lights don't light up. I checked around with DMM from youtube videos but didn't find a really good diagram except the one from 3090 FE. Going by that it looks like this is PEX? In that case the last option is to lift the coil and see which side is shorted or GPU is gone?
                                      This card started out used with a bad HDMI port and worked for about a year. Guess it doesn't work anymore. I was going to send it to a repair service in case of mosfet or some tiny IC they can air station swap. If the...
                                      01-31-2025, 12:13 PM
                                    • pc_okay
                                      G703GXR Dead CPU? shorted CPU power mofset replace, missing DRAMRST#
                                      by pc_okay
                                      Hello friends,
                                      I replace a shorted mofset (PU8104), now laptop is starting but no display, stopping at DRAMRST#.
                                      Resistance to ground on PL8104 is around 1-2 ohm, quite low but voltage seems ok 0.995V
                                      Any help would be appreciated it's a nice laptop !
                                      Thanks. 😃
                                      04-02-2025, 04:48 AM
                                    • fallenapples
                                      Acer Helios 300 N20C3- Dead Shorted mosfet blows
                                      by fallenapples
                                      Hey all
                                      Have the above laptop which is shorting out the power supply. 19v when plugged into the wall then when inserted into the laptop ir reads nothing untill you remove it from the wall and plug it in again.
                                      i found PQZ3 shorted so removed and confimed short gone.
                                      replaced PQZ3 and it shorted again?
                                      ive removed PQZ3 again and tested pads but theres no shorts there.
                                      11-07-2023, 09:44 AM
