Sanyo LCD-32E30A U/S Mainboard?
  • dkneyle
    • Dec 2013
    • 441
    Just to check if me expert mates agree with my diagnosis before I put this one aside.
    We've got all voltages come up except the Inv-On signal from the mainboard. Flashlight test reflected off the panel shows no signs of life. At power up the speakers make a crackling sound and when the Power-On button is pressed we again get the same crackling sound.
    The Inverter has 24 volts to it but as I say, no Inv-On signal. I can see it goes from about 0.00v to 0.02v at power on, so there's a little bit of something trying. My diagnosis is that the mainboard has failed somehow.
    Do people agree?
  • ammarben
    • May 2013
    • 63
    • algeria
    Re: Sanyo LCD-32E30A U/S Mainboard?
    i have asharp aquos with the same symptoms it was the mainboard failed somehow
    • dkneyle
      • Dec 2013
      • 441
      Thanks mate, you seem to have confirmed what I thought was going on.
      • newtothis
        • Mar 2013
        • 1556
        • england
        Yes if no BL-ON is being sent by the main it is indeed the main at fault
        • Mirenia
          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
          by Mirenia
          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
          03-30-2025, 06:47 AM
        • orcic
          MASTER TL240 and new mainboard LW36BKC01
          by orcic
          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
          Now I have some doubts about how to connect the new mainboard to the old power supply.
          First of...
          05-12-2023, 08:10 AM
        • Devonavar
          Vizio M43-C1 - How closely do I need to match the mainboard number?
          by Devonavar
          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
          So, I've ruled out the PSU for now.
          The reboot loop...
          08-14-2022, 08:46 PM
        • Malva
          Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
          by Malva
          I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
          Mainboard model: EAX65684604
          PCB marking: EBT62954607
          SPI chip: Winbond W25X20CLNIG Problem description:
          Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
          After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
          • I bought another
          06-25-2025, 02:07 PM
        • l0lhaxz1
          QN65QN90A - Mainboard MLCC failed - now bootloop
          by l0lhaxz1
          Hi
          I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
          Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
          Came to learn after a bit more research...
          02-06-2023, 08:59 AM
