Found an old tube TV. Want to find out more about it.
  • SteveNielsen
    replied
    Re: Found an old tube TV. Want to find out more about it.
    Pretty cool. I doubt any of the TVs made now will last 50 years.
  • Mrx3750
    replied
    I decided to make another video... just because I could...
    https://youtu.be/rQiWICi4-3k
    And the camera on my phone, for some reason records in a 16:10 aspect ratio, yet scales the video to 1280x720 which is 16:9, resulting in a squashed aspect ratio. It also records in a resolution much lower then 720p, so in this video I've corrected these faults as best I can.
  • Mrx3750
    replied
    That remains to be seen whether or not I'm keeping it. That said, the power cord is intact, the casing is not cracked or frayed, and it's interlocked with the chassis, so I don't see a safety issue here.
    replied
    for safety i recomend a new power cable if your keeping it.
  • Mrx3750
    replied
    Turns out I was mistaken about there being a bad tube. All the TV needed was a few tube sockets cleaned with contact cleaner.
    Check it out now:
    http://youtu.be/n3hg0GpWqVs
    How lucky am I to find a 50 year old TV, sitting on a curb, and all it needed to provide a good picture was cleaning pots, switches, and a few tube sockets.
  • Mrx3750
    replied
    Originally posted by Alastair E
    Err--You cant just switch valves around--Unless they are EXACTLY the same number/type.....
    --There are THOUSANDS of Different Type Valves--And many LOOK Nearly Identical to each other--but are NOT interchangeable!
    --A set that is basically working--with sound and full frame, then frame-collapse and no sound when two valves are transposed suggests the valves are Different Types to me!!
    Switch 'em back to the holes they came from!!
    A 6BL8 is a small signal Triode Pentode valve, the same as the Euro ECF80 These are often used as Line Oscillator/Sync Sep valves. Maybe in your set--Its the Vertical Oscillator/Sync Sep. Many UK sets used the PCF80 which is a 9V heater version of your 6BL8 for Timebase and sync sep as well as Video Output.
    --Had a short hot life used as video amplifiers in 1960's Bush TV105/125 series....
    Calm down. I know what I am doing. I've posted about this TV on Videokarma and I was advised to swap tubes. Also look at the pic I took of the tube sheet. The tubes I swapped are both 6BL8's... This Tv uses three of them, one for horizontal, one for vertical, and V 11 which is for noise and clipping. The V 11 tube is either bad or very weak. I swapped it with the V7 which is the same tube, and lost vertical and sound, which is what V7 controls.
    so I need a 6BL8 tube
  • Alastair E
    replied
  • Mrx3750
    replied
    Yes I have a DTV box. Feeding this TV a signal is not a problem. And I used to watch Channel 9 before they killed off the analog transmitters.
    problem is I need a 6BL8 tube.
  • Skiver
    replied
    Man, you are just 3 years too late to watch Channel 9 OTA from Windsor. Do you have one of those coupon converter boxes?
    A friend of mine worked for Motorola TV. I think he lasted two years after Matsushita bought them out (Quasar). (Motorola's motto: If you can't beat them, try to unload your unprofitable division on them.) Their color TVs used plug in cards for easy repair ("the works in a drawer, and the drawer in the shop").
    Chicago was the hub of the American consumer electronics industry. The private label Warwick and Wells-Gardner; the branded Admiral, Motorola, and Zenith. Our first TV was a Hallicrafters, we had a Webcor record player, later a Wollensak tape recorder.
  • goontron
    replied
    one certain TVs the selenium or germanium diode in the vertical hold can fail. i would check that. its usually a metal canned diode, not plastic.
  • Mrx3750
    replied
    Swapped V8 with V11
    Picture collapsed to a line and no sound. I think I found the culprit.
    So I need a 6BL8 tube. They're pretty common on eBay, but no $ to spend on one right now.
    Anybody in the Detroit area want to donate a tube?
  • SteveNielsen
    replied
    Yeah probably. You know anyone with a tube tester? If you want to then pull the chassis out (taking ALL necessary precautions as others have stated) and post some pics of the underside. Old school `tronics is interesting. To me anyway.
  • Mrx3750
    replied
    Okay, swapped V7 and V8 around, and that *almost* stabilized it.
    So am I looking at weak tubes, or some electronic component that's drifted out of spec in the last 5 decades
  • SteveNielsen
    replied
    Vertical linearity. It is used to adjust and even out the vertical spacing of the picture using a test pattern. The control might be recessed and need a small screwdriver to tweak it. Check horizontal and vertical oscillators V7 and V8. They are the same tube # so you might try swapping them and see if it stabilizes.
  • Mrx3750
    replied
    I readjusted the controls, this time paying attention to just what I was adjusting. Vertical and horizontal controls work fine, but I can't get horizontal or vertical to lock in place.
    Here's a (crappy) video of it now:
    http://youtu.be/2agduuDwDL4
    A control on the back is missing a knob. It's labeled 'VERTICAL LIN". Not sure what it does or if it's related to why the image won't stabilize. Perhaps there's a weak tube inside the set.
    If it's something easy that I can fix, I might give it a go, but I'm more interested in giving this set to somebody more familiar with tube TV's then trying to restore it myself.
  • kc8adu
    replied
    great!
    just watch things like the temp of the big cap can behind the transformer and the flyback.
    might want to check cathode current of the horizontal output tube.too high and fly runs hot as well as the tube.clean the tuner,controls,ect and enjoy your working antique!
  • Mrx3750
    replied
    Way ahead of you. It has a picture but needs cleaning and adjustment. Working on that now.
    replied
    now you need to feed it wih an anlog signal - got any old games consoles?
    or bypass the tuner to feed CVBS into it.
  • Mrx3750
    replied
    Hey guess what?
    It's alive! (Sorry for the crap picture. The phone that I took the first pictures on... the one with the good camera... yeah it decided to die on me last night, so I had to rush out and buy a cheap phone to get by until I get some money.)
    In any case, sound and picture works, and the set seems to be new enough to have mylar caps instead of wax.
    replied
    Originally posted by stj
    love it - hardcore fault diagnosis!!
    i knew a guy that used a similar method on digital stuff, he ran it for a few min's and then touched every chip till he burned his finger!
    Same way as other people that is trying to find the shorts on the circuit board by forcing current through the board and check for which component gets hot.
    I think there is a couple threads here that the guy is trying force 10 or 20A through the board to locate the shorts.
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • DCJack
    B&K 707 tube tester. I need help.
    by DCJack
    Hi everyone!
    I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
    Initially I noticed that I was not getting the red on-light to turn on, but it...
    03-05-2024, 05:05 PM
  • danielgerman681
    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
    by danielgerman681
    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
    08-27-2025, 01:17 PM
  • Schoenradt
    ECH81/6AJ8 Vacuum Tube Question
    by Schoenradt
    Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
    06-10-2021, 05:49 PM
  • corrize
    Where to find a very small fpc connector 0.3mm between 2 pins ?
    by corrize
    Hello, I search this connector (oxydated).
    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
    Do you know how to find this connector please ? What is the exact name for find it ?
    08-06-2024, 05:25 PM
