50PFP5332D Philips - worth fixing?
  • teeveetroubleddutch
    • May 2015
    • 7
    • united states
    Hey y'all.
    Total newbie here. Have some electronic experience and know my way around a dmm.
    Have this super nice 50 inch plasma 50PFP5332D TV that is acting not so nice. Was given as a project since owner didn't want to mess with it and just went ahead and bought a nice LCD. Have done some homework on this site and have so far determined that the power supply is putting out correct voltages. No bulged caps or weird nonsense. Shows heartbeat pulse on controller board and blue light comes on in front. Both relays click in and both y & x mains make their characteristic high volt humming noises. Disconnected y-main and powered up - no picture. I am pretty sure y main is cooked since the two resistors between the buffer connectors have been crackelacktically cooked. So no go with x-main connected. And from what I understand, screen should light up with x (z?) Main connected. Not really sure how to test for sound throughput since I don't know whether or not TV picks an active input automatically or if I'd need a remote to switch it.
    Do I have any way to make sure this panel would still work before replacing boards and finding out there's no gas in it? It looks flawless. No cracks or other weirdness, but it not lighting up with x (z?) Connected makes me a bit hesitant. Could be bad x (z?) As well but not sure how to go about troubleshooting it. Fuse is Ok and supply is pushing some 200 someodd volt in that direction..
    Any pointers would be greatly appreciated.
  • Hamie
    • Apr 2014
    • 1383
    Re: 50PFP5332D Philips - worth fixing?
    More than likely your y-sus and buffers.
    This is effectively a Samsung PS50Q97HD but wrapped up in Philips clothes.
    You'll probably find shorts on the lower heatsink on ysus and shorts on the top
    2 buffer ICs, it's an expensive fix even if you're doing it at component level.
    You need to have decent soldering experience if you want to repair the buffers.
      • May 2015
      • 7
      • united states
      Much appreciate the reply. Looked into getting y-main repaired and finding some working buffers. I think I figured out that that's relatively costly. But even despite the cost, would it be worth it considering the screen doesn't light up with the y circuitry disconnected? And just the z connected to the power supply? Or could fried y boards cause the screen not to light up with just the z connected? Its a nice TV and I'd like to try and salvage it..
      • Hamie
        • Apr 2014
        • 1383
        The y makes the screen glow not the z.
          • May 2015
          • 7
          • united states
          Ow cool! Alright. Will see about replacements and report back
          • alro7779
            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
            by alro7779
            Hello, guys!
            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
            09-14-2025, 12:25 AM
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
          • iamwise
            Asus TUF Gaming F15? Is this worth fixing? PCH WARM
            by iamwise
            Hi all, I picked up a liquid damaged Asus TUF Gaming F15, does not power on, model FX506HM-HN004T.
            Ive gone as far as removing the case and doing a visual check, there is no visible corrision, upon plugging in the power brick a single led light shows that power is plugged in, but no display or fans, the PCH chipset gets warm/hot to the touch, could this mean its not fixable or do I proceed and remove the motherboard completely and check further for shorts etc, failing that should I just take it to a service centre and go from there
            what would you do? my skillset is...
            08-03-2022, 05:06 AM
          • double_DD
            Philips curling iron - is this a common AC cable?
            by double_DD
            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
            08-18-2025, 10:04 AM
          • janos6662000
            Philips 47PFS7509/12 LCD TV problem
            by janos6662000
            Hi
            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
            When i applied cable signal to check image, i had normal picture, but TV was restarting.
            I downloaded original firmware and applied the update, but the problem remained.
            From a colleague i received a "factory package software" which is a lot bigger.
            I made another firmware update, but still did not solve the problem.
            Somewhere on the way the error got worse, because at the moment the...
            08-12-2025, 12:54 PM
