Suggestion for Panasonic Replacement Cap
  • adiapp
    • May 2015
    • 12
    Hello everyone - 1st post - I was hoping someone can help me with the closest spec of a Panasonic cap for the Samwah WB series on my board
    The TV model is LN52A650A1FXZA
    The power board with 2 bulging caps - BN44-00201A
    The 2 cap locations are CM851 and CM852 - both caps are identical
    The 2 caps are Samwah WB 1000uF 25V 105C Size 12.5x20 MM
    Pics are attached along with the WB series data sheet in PDF -
    I can use Digikey or Mouser
    Based on the reading I've done here I would like to go with Panasonic replacements I am not sure how to pick the closest specs in Panasonic (other than the obvious 1000uF and 25V) . If someone could assist me with that it would be greatly appreciated.
  • Hamie
    • Apr 2014
    • 1383
    Re: Suggestion for Panasonic Replacement Cap
    Really any good brand low esr capacitor will do.
    Panasonic FR series are my usual replacement.
    I buy them form HM Comp on eBay, but don't know if they deliver in the U.S.
    Also I'd replace the caps next to the ones that have failed just for good measure.
      You can get Panasonic caps from Digikey in the US.
        Just find the right values and dimension in the spec sheet, then type in PANASONIC P/N into the DIGIKEY/MOUSER search box.
        https://www.badcaps.net/forum/showpo...2&postcount=65
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          I wouldn't be too fussy--The set is a fair age (7 years!)--even a cheapo crappy 105 deg C cap of the right value will outlast the rest of the set!
          TELEFIX
          • adiapp
            • May 2015
            • 12
            OK thanks - Ive narrowed it down on Digikey - I can kick myself - had a great desoldering gun with a vacuum on it - gave it away a few years ago - anyway - the set was purchased in 08 by a friend and in 2013 Samsung replaced some caps in August of 2013 - so 1 1/2 years later - these 2 caps are bad - I am guessing they didn't want to go the extra 1.50 to finish the job - go figure - Thanks again for the responses and if I may ask - on the Digikey table - the column for ESR is blank - just has a dash in it - I've filtered to FM and FR - they do not list an ESR - or can I just assume these will be a low ESR
            • Terryfictv
              • Mar 2011
              • 124
              Another good source is www.bdent.com
              • LLLlllou
                • May 2011
                • 201
                UCC KZE is an almost exact match. Same size, same ripple, slghtly lower ESR, and same 5000 hour endurance.
                http://www.digikey.com/product-detai...1681-ND/756197
                • LLLlllou
                  • May 2011
                  • 201
                  ESR on FM and FR are lower than WB, but ripple is also lower. if you have room for 22mm height, 35v FR will work.
                  For some reason Digikey doesn't show ESR, just impedance, which is essentially the same.
                  • Jagster
                    Panasonic SA-XR25,Looking for a good replacement cap
                    by Jagster
                    I have a Panasonic SA-XR25 surround receiver that is not working and I believe it may have a faulty capacitor. This large capacitor near the mains power input has a plastic top that is bulged out. Anyhow, I'm trying to find a like replacement but Panasonic doesn't seem to make this capacitor any longer and I want to find a suitable replacement. It has an "AUDIO" designation written which I presume means something important in relation to the capacitors design characteristics. Can someone advise on what would be a good replacement? Image attached.
                    The sleeve info:
                    10-27-2022, 09:34 PM
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                    11-20-2024, 08:52 PM
                  • AquaMan Ua
                    by AquaMan Ua
                    05-17-2025, 09:40 AM
                  • thuss
                    Panasonic 55AS802b Mainboard replacement
                    by thuss
                    Hi
                    My Panasonic turns on but wont go past the Panasonic logo.
                    From what I have been told its a poorly designed main board that couldn't handle a firmware update.
                    Panasonic want a whopping 350 pounds for a replacement board.
                    I've been told that certain Seiki tv mainboards are compatible with my 55As802B.
                    Any advice or which Seiki tv model has the compatible mainboard (I cant find one)would really be appreciated. (tried various combination of buttons but it wont go past the boot page)
                    Thanks in advance
                    12-29-2019, 02:23 PM
                  • the_rem
                    Unknown transformer : how to find a good replacement part ?
                    by the_rem
                    Hello guys,
                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                    04-23-2025, 01:48 AM
