Samsung PN 50b55ot2f, No Picture, has sound
  • sky608
    • Mar 2015
    • 7
    • ca
    Hi, This is my first post. I have checked the VA 56, reads 56.4dc, VSC -200, reads -198, VS 208, reads 207.6, VE 92, reads 92.2. The control board green led light is flashing normally. All the fuses including the green ones are good on the y main and x main. I noticed the x main has a buzzing noise and the top heat sink is warm and bottom heat sink is hot. The y main has power to the fuses but both of the heat sinks are cold. I did pulled the y main and x main out and visually look at it and found no unusual burnt marks.
    Re: Samsung PN 50b55ot2f, No Picture, has sound
    Is there a slight glow from the screen in a dark room?
    No cracks on the panel?
    • sky608
      • Mar 2015
      • 7
      • ca
      hi tom, thanks for the input. You are very helpful in this forum. I don't see any glow when i power on the set in a dark room I don't see any crack on the panel. Does this mean the panel is bad?
      Thanks...
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • jchang
        Samsung UN70NU6900F no picture and no sound
        by jchang
        Hi all
        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
        Symptom:
        No picture no sound.
        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
        No sound at all.
        What I tried:
        1. I tried unplugging the left or right ribbon...
        01-09-2023, 06:28 PM
      • marekk
        Samsung QE55Q67RAT no sound and bad picture when streaming
        by marekk
        I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
        I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
        Mainboard is based on pcb BN41-02695A BN94-14007B
        I will appreciate any help
        Many thanks
        Marek...
        05-29-2025, 02:23 AM
