Hello, I recently had a shortage/surge in my house due to a screw that scrapped off the rubber coating, and the electricity was grounding back into the stove. So if anything metal touched the surface of the stove, and connected the two burners, there was a huge ball of plasma that would form, and melt whatever piece of metal that was completing the circuit. That issue has been fixed, but it left me with a blown out TV. I took the back panel off, tested voltages all over the place, they all looked good, but I got another power supply board just to make sure. That board came in today, but the problem still persisted. It clicks two times back to back, and then a third click about a second after. Now, I disconnected the cable that connects the power supply board to the main board, and the TV hums like it did when it was working, and the screen lights up but nothing appears. Upon reconnecting the cable, it clocks three times, stops humming, and the screen goes black. So is this an issue with the main board, since the TV stops virtually all operation when the cable is connected to it? Both the sustain boards are working correctly I should have added earlier.
Possible LG 42PJ350 Main Board Problem?
Tags: None
Re: Possible LG 42PJ350 Main Board Problem?
Look at your control board. (Small board below the power supply)
There should be 2 holes marked ext_auto_gen
Connected the 2 holes with a piece of wire.
Disconnect the LVDS going to the mainboard.
Start up the TV and if you get test patterns on screen you need a new mainboard. -
Yep. Test pattern. Sigh... Spend $40.00 on a new power supply board, thinking that was the problem. Wish I had joined this forum earlier. Thanks for the help though!Last edited by pilotguy251; 05-09-2015, 06:46 PM.Comment
You should be able to return it, lots of eBay sellers have return policy's (assuming that's where you bought the powersupply)
Even if they don't you should have no problem reselling the power supply for this set as they break down all the time.
Or if it's a TV you're keeping, keep a hold of the PSB, because you'll probably need it sometime in the future.Comment
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... - Loading...
