scren for lg M2762DL
  • xalien
    • Feb 2015
    • 65
    • thessaloniki
    Hi Can somebody help me to find this screen M270H1- L01 REV C01 i want and used it is for LG FLATRON M276DL
    Thanky
    Re: scren for lg M2762DL
    That is a Chi-Mei part number. Are you looking to buy one? I have fixed T-con fault on a very similar panel before, with burnt diode on T-con. I thought panel was bad, but it was OK.
    • Bitvive
      LG Flatron starts w. coil whine and power issues
      by Bitvive
      Hi ,
      My old LG Flatron recently started with coil beeping. This got worse every day for a few days until it also started having power problems.
      Now it also went off again after displaying the LG logo, then on, off again, then on and so on...
      So far I have measured the power supply unit, which delivers 19.21V and should therefore be OK. I removed the circuit board and connected it to the mains plug so that I could hear the coil beeping.
      During the beeping, I pressed on the coils with a non-conductive tool to see if the sound changed and to find...
      08-18-2024, 06:34 PM
    • conrado.g
      LG Flatron W2353V no power on, nothing.
      by conrado.g
      Hi folks,
      This is my first post. Richard over at YT Learn Electronics Repair recommended this forum in one of his videos. I am learning electronic repair now in my thirties.
      I have an LG Flatron W2353V that doesn't power on. It just stopped working from one day to the next. No lights, no nothing, and I don't know how to test the keypad since it doesn't have buttons, just a touch keypad. I took out the power supply board, and am attaching pictures. Some of the capacitors are bulged. I have a multimeter and have tested voltage at several places:
      Capacitors:...
      06-01-2023, 09:07 AM
    • canadaboy25
      LG Flatron 24EN33TA No Backlight When Cold
      by canadaboy25
      I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
      I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
      03-07-2023, 12:23 AM
    • Ancient1
      LG Flatron L1953TR : CCFL connectors confusion ( forgot to take a photo before disassembling )
      by Ancient1
      I forgot to take a photo and now I am not sure how to reconnect
      As you can see , I have 2 pairs , each pair has 2 colored wires : the black_ish connector and blue_ish connector
      There must be a convention to help decide , I assume
      How do I reassemble ?
      03-07-2024, 04:35 PM
    • goodpsusearch
      LG Flatron L207WT repaired
      by goodpsusearch
      Got this 8 years ago for 10 euros, seller said he tried to repair psu and destroyed it but panel is OK.
      Used panel to fix another LG 20" model LG Flatron L204WS that found near dumpster with broken panel.
      Used panel of L207 on L204 and kept L207 for parts.
      1 month ago troubleshooted Samsung 20" I also found for free, turned out the Samsung had mainboard bad. Tried to reflow, no change.
      So, I decided to use the panel of Samsung and try to fix the LG L207 too.
      I attach pics after repair of the power supply that...
      01-15-2022, 04:09 PM
