problem with 32" Samsung TV
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi guys got a samsung 32" tv which has funny colours blended in with the picture / mostly on whites. anyone know what could be the issue, im guessing T-Con but unsure.. have attached a short video to let you see what im on about.
    https://www.youtube.com/watch?v=moPsMS_k30w
    Re: problem with 32" Samsung TV
    Pictures of the T-CON board? Model number of the TV?
    Looks like the GAMMA Voltages are off a little.
    Try re-seating the cables first. tightened all the board mounting screws, etc.
    • CapLeaker
      Leaking Member
      • 8221
      look if your tcon has a AS15 chip on there. Maybe make a nice pic of your tcon board and post it.
      • infringer
        Badcaps Member
        • Sep 2009
        • 244
        • United Frickin States
        look at the LVDS ribbon cables ....
        The ribbon cables connected to the TCON and the Monitor I am guessing they are crooked or not making a good connection especially if they are dots often blueish in color.
        Enjoy hope this helps fix yah!
        Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
        • steviewonder
          • Dec 2013
          • 183
          • england
          99.9% certain the as15-F has failed.The RM5101 is a much more reliable replacement.
          For a quick test,leave the metal tin off,switch the set on and you will find the i.c is red hot if you put your finger on it.
          Replacement is easier than it looks,I use a Stanley blade,cut all the legs off in situ,then use some wick to remove the legs still on the board,then a fine iron to fit the new one.
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            Hi guys sorry for slow update, this is the T-Con from the tv and cant see the AS15 chip on there, anyone else have any other suggestions, tried reseating ribbons and problem continues
            • vinceroger69
              • Mar 2012
              • 6714
              i cant see it either maybe reconnect the t con on the top right of the board theres some gamma test points 18 i think maybe test each point and post voltages.
              • delboydev
                • Sep 2013
                • 4
                Ribbons on the panel, take the panel apart and apply pressure to the ribbons see if it changes. Report back mikey!
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  ok so put tv back together to test voltages and the tv switched on by itself and hey presto it seems to be fine.... will it stay like that or is there a chance it will come back ?
                    A problem that goes away on its own will come back on its own... at the worst possible time... and in the worst possible place
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      lol i like how you put that Tom......
                      • THXFX
                        samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                        by THXFX
                        Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                        I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                        When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                        What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                        I check capacitors and diodes and didn't find any short IN MAINBOARD.
                        Measured all power supply...
                        03-20-2024, 03:21 AM
                        09-07-2024, 05:50 AM
                      • howardc64
                        Samsung UN55JU650DF network/streaming problem
                        by howardc64
                        Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                        This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                        07-09-2025, 12:44 PM
                        09-06-2024, 11:40 PM
