Panasonic TC-P54S2 plasma TV--won't turn on, originally 10 blinks, now 7 blinks
  • JoeyB
    • Mar 2015
    • 34
    Re: Panasonic TC-P54S2 plasma TV--won't turn on, originally 10 blinks, now 7 blinks
    Got it, thanks.
    • JoeyB
      • Mar 2015
      • 34
      At long last, here are my readings:
      original SC board:
      SC2 connector pins: 67.3K
      TP82: 3.55K
      C561: 5.61K
      replacement SC board:
      SC2 connector pins: 395K
      TP82: 4.1K
      C561: 5.6K
      original SU board:
      pin 2: no reading
      pin 4: 221K
      pin 8: no reading
      replacement SU board:
      pin 2: no reading
      pin 4: 220K
      pin 8: no reading
      original SD board:
      pin 1: no reading
      pin 2: 219K
      pin 6: 16.28Meg
      replacement SD board:
      pin 1: no reading
      pin 2: 220K
      pin 6: 16.17Meg
      Thanks--
      • tw2005
        • Oct 2011
        • 6458
        Ok, so it's going to take a bit to work through this because there's not a lot of conclusive evidence to be 100%.
        The buffers I'm going to say both sets are good and your meter is having trouble reading the higher resistance. if they were an issue we would see low ohms or shorts and the 221k at least is good which gives credibility.
        TP82 is higher than i'd expect but depending on which way the probes are placed it will give different results. you could measure that again but place the probes in both directions to get both results so the variation there I can't get anything from. That resistance can go low depending on how bad IC521 is damaged as the 15v feeds that IC.
        SC2 on the original is lower than normal so I'm comfortable saying it's bad.check Q661 on that and see if shorted.
        So this leaves us now with the predicament of nutting out the current 7 blink.
        Firstly, lets try and eliminate A-board for 7 blink.
        Disconnect the following, sc2,ss11, 3 white ribbons at the A-board, p35.
        Now turn the TV on as normal and confirm if it starts up normally and stays on. There will be no picture.
        You may wish to backprobe the P2 or P11 on the p board and see if Vsus (200v) is up and running, this also confirms the TV is in a running state.
        Run no more than 30secs , turn off and do NOT reconnect any leads Sc2,ss11 or P35 for 5-10 mins or get the meter and check there is no voltage left there. You can damage the panel with p35 if connected with residual voltage.
        Assuming this passes as expected, this is the next step.
        Once safe to do so, reconnect all cable and leads, ribbons. (excluding buffer to sc connections) double check everything is correctly seated and all mounting bolts are in place on the SC.
        Leave the sd/su disconnected from the Sc, make SURE, the 4 bolts that attach the sd/su to the Sc are REMOVED.
        On the Sc board there is a small white 2 pin connector SC50. Short those 2 pins together, an alligator clip can just get in there or maybe an old IDE hard drive jumper may fit.
        turn the Tv on and see if 7 blink. if it does then there's something on the Sc bad, if no blinks then by rights the TV should work with the SD/Su connected again and the 4 bolts in place.
        With the sd/su there is a small ribbon that connects the 2 boards, make sure that's in place
        • JoeyB
          • Mar 2015
          • 34
          Thanks--it's time for bed here now so I'll try all that tomorrow evening.
          Thank you very much, I really appreciate it.
          • tw2005
            • Oct 2011
            • 6458
            I have to make a small correction. if the meter reads 16meg then it should have read something at the no reading positions. try reversing the probes on those but more importantly so long as you have tested the correct pin then i'm happy. if you found pin 4 then 2 & 8 are on the same side of the connector as 4. Pin 1 would be on the opposite side of pin 2.
            I have seen this before, must depend on the brand of meter, so long as the correct points were tested then we'll assume good for reasons previously mentioned.
            just for clarification, when you say no reading , is that OL or what does the display do? Not 0.00 I hope.
            • JoeyB
              • Mar 2015
              • 34
              Okay. Eliminating the A board, the set did stay on. At the moment I am letting it sit while the voltage dissipates.
              As for the questions in your last post, by no reading I meant OL. And reversing the probes I found I did get some readings:
              Old SU
              pin 2: 13.21Meg
              pin 8: went over 20Meg, which is the max for my meter, then OL
              Replacement SU
              pin 2: 13.35Meg
              pin 8: also >20Meg
              Old SD
              pin 1: 13.12Meg
              Replacement SD
              pin 1: 13.8Meg
              • JoeyB
                • Mar 2015
                • 34
                Continuing with the next step, I still got 7 blinks. I couldn't find a proper clip so I improvised by bending a paper clip so it would fit, but I feel like it was doing the job adequately. Also, when removing the 4 bolts, there was a 5th bolt in between the SD and SU boards. I left that in.
                Thanks.
                • tw2005
                  • Oct 2011
                  • 6458
                  Thanks.
                  well, not sure how good a paper clip works but you could put it in position then probe the 2 pins and confirm shorted and then test again but with the additional info on the buffers, they're ok and if definitely 7 with the sc50 jump then you got a bad Sc sent to you.
                  The other result for the A board is exactly what we needed as it means it's a genuine 7 blink from the Sc.
                  So good news as far as fault finding is concerned but now you have the added expense of another Sc if you can't get a refund but my advice is consider moduslinkpts for rebuild
                  • JoeyB
                    • Mar 2015
                    • 34
                    Replacing the SC board is what made it change from 10 blinks to 7--so that just means the two SC boards were bad in different ways?
                    I'll get ahold of a different clip to be sure on the SC50. Thanks for the suggestion of moduslinkpts, and thanks a lot for all the help!
                    • tw2005
                      • Oct 2011
                      • 6458
                      Pretty much. depends on how bad they destruct. If SC2 goes short usually 4 blink. 10 / 4 blink is pretty common . you can get a variety of blink codes when the SC goes.
                      Even had a 1 blink which I honestly did not expect to see but when I got the OP to just power with the A board like you did, incredibly it passed. Learn something every day.
                      Normally with 1 blink A board is the fault but it was just luck that I suggested checking it.
                      • tw2005
                        • Oct 2011
                        • 6458
                        get your order in now if going moduslinkpts, 25% off 1st 2 weeks in may. must be longer weeks in the USA now being the 15/16th may
                        that's $51 for this board if you get going and book it online now. have not seen an end date but must be very close
                        • JoeyB
                          • Mar 2015
                          • 34
                          I can still send the faulty replacement SC board back for an exchange. I'm supposed to write on a copy of the invoice "what is wrong with the board." How would I best describe that?
                          Thanks a lot, again--
                          • tw2005
                            • Oct 2011
                            • 6458
                            first up, get your meter and check Q661 either resistance or diode mode for shorts between any 2 legs and let me know.
                            I'll let you know once I have that info, but I'm thinking , sd/su boards confirmed good, installed SC - 7 blinks, isolated sd/su boards, performed panasonic sd/su isolation test, sc installed still 7 blinks, SC board is faulty.
                            • JoeyB
                              • Mar 2015
                              • 34
                              Can you tell me where Q661 is? I'm having trouble locating it--
                              Thanks!
                              • tw2005
                                • Oct 2011
                                • 6458
                                Thanks!
                                look at my profile image, small heat sink top left corner has 2 transistors, location q661 is marked(rjp63f3a) see if shorted
                                • JoeyB
                                  • Mar 2015
                                  • 34
                                  I'm not finding a way to enlarge your image with any resolution...
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Try comparing the image to your board and look at it in front of you
                                    • JoeyB
                                      • Mar 2015
                                      • 34
                                      What I'm saying is that I can't see anything in the tiny image at the left, and I can't find a way to see it on a larger scale. I can save the image to my computer and then enlarge it, but then it's blurry and I still can't see anything in it.
                                      Thanks--
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        • JoeyB
                                          • Mar 2015
                                          • 34
                                          Thanks--I never would have found that. In diode mode I got 1.194 or .753, depending on what order I put the leads, using the outer legs. In resistance mode I got 2.23 K either way.
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • nick31
                                            Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                                            by nick31
                                            My Oct 2012 panny plasma quit working yesterday.
                                            It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                                            Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                                            I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                                            04-21-2021, 09:56 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                            Having said that I come to the gist of my post on the forum as the title suggests.
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
                                          • Biruslapio
                                            Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                            by Biruslapio
                                            Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                            It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                            It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                            02-16-2021, 09:44 PM
