insignia ns-lcd 32 tcon ?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    just plugged this baby up thinkin proly bad tcon ?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: insignia ns-lcd 32 tcon ?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Double post.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Go into the service menu and check if the lvds mode is on if so turn it off, either that or tcon, mobo or lcd screen is bad.
        • mattstolte
          • Dec 2013
          • 612
          • usa
          Recey this is no double post. How do I get into the service menu
          • mattstolte
            • Dec 2013
            • 612
            • usa
            how can I go into the service mode and try this
            • vinceroger69
              • Mar 2012
              • 6714
              try input 2580 (tv is on)
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                08-20-2025, 06:04 PM
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
