Panasonic tc-p65s2 dead 10 blinks
  • rageed
    • Apr 2015
    • 13
    Hello everyone I have a Panasonic that I am attempting to repair, when plugged in I can hear 2 relays , then nothing other red Led on front blinks 10 times , then repeats ,
    from what limited info I can find I believe that trouble points to the A board .
    Looking for any advice anyone can give
    thanks in advance
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic tc-p65s2 dead 10 blinks
    you're going to have to take the back off and start isolating items to narrow it down.
    10 blinks could be just about any board. SC board comes to mind. Try disconnecting sc2 and see if it goes 7 blinks.
    avoid reconnecting the cable for 5 min as there can be 200v residual with the TV off.
    • rageed
      • Apr 2015
      • 13
      Thanks tw2005 I will do this and report back
      • rageed
        • Apr 2015
        • 13
        looking at the board allocation I do not believe this set has a sc2 board ?? so i disconnected the SC board and now I have 6 blinks
        Am I correct that this set does not have a sc2 board ??
        • tw2005
          • Oct 2011
          • 6458
          sorry, I need to be clearer for you. SC2 is the connection SC2 on the SC board but I suspect already this is SC board since 10 blink disappeared.
          What gear do you have? multimeter ?
          • rageed
            • Apr 2015
            • 13
            yes good multimeter
            • tw2005
              • Oct 2011
              • 6458
              yes good multimeter
              tis good it's good
              expect shorted components
              try Q661 and see if shorted(there'll be others)
              measure resistance
              across SC2 pins.
              Then resistance, these are near SC20 ribbon connector
              TP82 - a gnd point on the board
              across c561 or TP16,17 - gnd(are underside, c561 is easier)
              On the buffer boards measure these, highest resistance up 6 meg with respect to the gnd plate. 1 phot is SD, other is SU, different pins.
              • rageed
                • Apr 2015
                • 13
                Thanks TW2005 , will check
                • rageed
                  • Apr 2015
                  • 13
                  tis good it's good
                  measure resistance
                  across SC2 pins.
                  quick check shows Q661 shorted and when looking closely Q423 is actually blown apart
                  • rageed
                    • Apr 2015
                    • 13
                    tis good it's good
                    measure resistance
                    across SC2 pins.
                    So looks liker the Sc board is where most all troubles reside , would you suggest replacing whole board or replacing components ?? and where to get board ??
                    • tw2005
                      • Oct 2011
                      • 6458
                      not often youi get to seee a blown apart IGBT on these but I think you found your 10 blink.
                      Buffer tests , will need the values. This is so you know where you're at as far as repairs needed. getting parts for a 65" could be challenging.
                      repairing the board, achieveable or send it to Modus for about $100
                      • tw2005
                        • Oct 2011
                        • 6458
                        What part number is stamped on Q661 and Q660?
                        • rageed
                          • Apr 2015
                          • 13
                          Q661 part # is RJP56F4Axxx082p shorted E to C
                          Q660 part # is RJK6026xxx0617
                          I will have to pull Q423 can not read part #
                          sorry I am new to this forum where/who is Modus repair ?? contact info
                          • rageed
                            • Apr 2015
                            • 13
                            also i tested Q425,Q424, Q422,Q421 D 421 are all show shorted on board is this normal ??
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              Test them out of cct you will most likely find they aren't all shorted.
                              • rageed
                                • Apr 2015
                                • 13
                                thats what i figured
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  Check the buffers too BTW, Ground the black probe in continuity mode (beep) and run the red down the buffer ribbon connections... If any beep that corresponding IC is shorted
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    tis good it's good
                                    measure resistance
                                    across SC2 pins.
                                    prefer you resistance check as per the photos, wiil need the values you get
                                    Often i find all DG402RP go short but that is on the smaller boards which usually only have 2 in parallel, you may get lucky. usually the diode survives.
                                    i would not pull the board apart unless you intend to repair the whole board yourself otherwise send complete to Moduslink PTS.
                                    there's normally a bunch of smaller SMD stuff that needs doing as well
                                    http://www.moduslinkptstvboards.com/TXNSC1MAUU/
                                    repair/return option
                                    • rageed
                                      • Apr 2015
                                      • 13
                                      finally able to get back to this !!! thanks again Tw2005 for all your great help !! just want to clarify some points before i send SC for repair.
                                      summery of where i am in respect to this tv.
                                      1) SC board is faulty plan on sending to Moduslink for exchange/repair
                                      2)wanted to ensure that SD and SU boards are not faulty , I am going to check that none of the pins on the ribbon cable are shorted to ground, but I wanted to ensure that I am talking about correct pins/ribbon cable.
                                      these are the cables that connect SD/SU boards to SC board correct ?? Currently I have Sc board removed and ribbon cable between SU and SD disconnected, I see pins on connector SD 46 (pins 3,5,7) are shorted to chassis ground(screw fastening board to chassis), rest of pins are at 30 Meg or so
                                      Faulty SD board as well as SC ??
                                      thanks
                                      • rageed
                                        • Apr 2015
                                        • 13
                                        Also forgot to give thanks to "newtothis"
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • mecha1166
                                          XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                          by mecha1166
                                          I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                          07-01-2024, 05:47 PM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
