Samsumg UE46B7000WW No picture but sound issue
  • papazaf
    • Apr 2015
    • 22
    • Greece
    I got a UE46B7000WW, when I switch it on, only shows white screen, some black vertical lines on the left side of the bottom of the screen until the middle of the screen and about 10cm in width.
    Dismantle it, I have found that the ribbon cable from the tcon to the panel was scorched, blackened pins and at the Left side had a hole. See photo (the back side had blackened pin)
    I Changed the two ribbon cables , but now I only have a black image and nothing else, the backlight is on, I have connect at the HDMI input; An external decoder and it gives me only sound, the picture is black (backlight is on).
    Than I also noted that the tcon has a burnt chip. .
    So far so good, my point is that the binding of ribbon cable to the panel has blown, try cleaning it, but as shown in the photo, it doesn't look good...
    Now I do not know if it has burned and nothing else on the pcbs of the panel, I don't like the looks of the smd capacitor c18 as shown in photo. Are those pcbs replaceable?
    Is there a way to see if the panels works without tcon?
    I am trying to find out if its worth the repair, or the panel is off..
    Any ideas?
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsumg UE46B7000WW No picture but sound issue
    Ok firstly driver boards are part of the panel and cannot be replaced.
    I am not sure what would of caused that other than liquid or misalignment of the connectors.
    I am not sure what to say to be honest, I wouldn't touch it with a bargepole?
    • papazaf
      • Apr 2015
      • 22
      • Greece
      I really don't know, my hypothesis is that a power surge , burned the tcon out, and then pass wrong current to the panel.
      Do you think that the panel boards are dammaged?
      The question is , is the panel ok or its gone?Is there a way to test it?
      • papazaf
        • Apr 2015
        • 22
        • Greece
        is there a way to find the model or the serial of the panel?
        • newtothis
          • Mar 2013
          • 1556
          • england
          Yes there will be a sticker on the back of the panel on the chassis
          • papazaf
            • Apr 2015
            • 22
            • Greece
            Is there a way to test the panel without replacing the tcon?
              Ah - are the stand screw holes in approx that area?
              Samsung had an issue where people were using stand bolts too long and they dug into the ribbon cables, causing damage.
              There's no easy way to test the panel without replacing the boards sadly.
              • papazaf
                • Apr 2015
                • 22
                • Greece
                No the stand bolts are ok,
                The tcon is damaged for sure, i am not able to see if the repair is worth it or not
                • papazaf
                  • Apr 2015
                  • 22
                  • Greece
                  I am finding varius tcons V460H1 on the web like this
                  http://www.aliexpress.com/item/Free-...8.4.170.EPOlvF
                  but i am confused, is it the right one?
                  • Dang
                    • Aug 2013
                    • 440
                    The ribbon cable to the screen looks very much like liquid damage to me, this has caused electrolysis and eaten, burnt and shorted out your contacts.
                      If that's the case, the panel could also be damaged so check the tab bonds for corrosion.
                      • papazaf
                        • Apr 2015
                        • 22
                        • Greece
                        the tab bond at the picture looks ok..isnt it?
                        • Dang
                          • Aug 2013
                          • 440
                          Look at the third picture, top left, very much eaten contacts, if it's not liquid damage and some other cause, then either way that screen is never going to work again, there's just too much damage.
                          • papazaf
                            • Apr 2015
                            • 22
                            • Greece
                            maybe restoring them using anisotropic paste?not woth a try?
                            • Dang
                              • Aug 2013
                              • 440
                              I don't know, if you want to try it as an experiment then go ahead but it really does look past it, it might just end up being money wasted, good luck though.
                              • papazaf
                                • Apr 2015
                                • 22
                                • Greece
                                thanks
                                  I did not see that damage before - definitely bad panel due to water. Shame.
                                  • papazaf
                                    • Apr 2015
                                    • 22
                                    • Greece
                                    the owner says that there wasn't any contact with liquids, one day just happened
                                    are the tab bonds replaceable?
                                      People lie. All the time.
                                      • newtothis
                                        • Mar 2013
                                        • 1556
                                        • england
                                        Yes as I said in my first post... Other than liquid or misaligned connections. I wouldn't even attempt to fix it... I 100% say you will not get it to work
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • benspawn02
                                          Anthem MRX500 - no sound. R2A15218FP issue??
                                          by benspawn02
                                          Dear Electronics Experts:
                                          I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                                          08-12-2023, 04:46 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
