Hi, I have this Tv which has no back light, it is an LED type so was wanting to know how best to test for a bad LED strip? I've tested the PSU and think all voltages are fine, I'm seeing 24-25 volts from the supply caps so quite certain there's no short there, I've tested pins 1-12 for the back light with the connector disconnected and the last five pins show 24.5v, the first 3.2v and the second 1.4, with the connector back in place only pin 2 drops to 0.3v, the rest of the pins I believe are ground. My thoughts are for a shorted LED but I'm not to sure how to test for that without taking the screen apart, so my question is how? thanks, Andy.
Toshiba 40D1333B no back light.
Re: Toshiba 40D1333B no back light.
I have seen 2 other sets like this with either a samsung or Vestel panel and the leds themselves were bad, in some cases the connectors going to the leds can become weak and will need reseating and adding a small layer of tim on them could get them back and working. Best option would be to take apart the screen and check the leds normally when they fail there will be a crack in the optic glass on top of the diode.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/ -
I have seen 2 other sets like this with either a samsung or Vestel panel and the leds themselves were bad, in some cases the connectors going to the leds can become weak and will need reseating and adding a small layer of tim on them could get them back and working. Best option would be to take apart the screen and check the leds normally when they fail there will be a crack in the optic glass on top of the diode.Comment
Normally you can just check the strip for a sort, if you see a cracked optic you can just break it off by wiggling it then check the diode.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
OK, cool thank you, I have to ask though, would a bad LED take out just a strip or would it take them all out until replaced?Comment
If they are connected in series, then it only need one open circuit to kill all the lights.
Can we see the pictures of the board? You can look at the connector and the circuits on the board to see how the LED strings are connected.Never stop learning
OK, let me analyze the board layout to see how the LEDs are connected.
OK, I cannot find anything at Shopjimmy to see if they have good pictures of the top and the bottom side of the board.
17PW07-2 power supply.
Can you please provide the pictures of the bottom side?
it looks like it has 4 LED strings (8 wires on the connector), 4 filter caps 1000uF/35V, so the drive voltage is not very high.Last edited by budm; 04-24-2015, 03:04 PM.Never stop learning
Schematic of 17PW07-2:
Like all Vestel schematics it's drawn terribly...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
OK, we are missing the LED driver board picture!
Can you upload the pictures of the whole back side of the TV.
That connector PL306 is just the output connector to feed 24Vdc, and backlights commands signals to the LED driver board.
TOM, thanks for the diagram.Attached FilesNever stop learning
I have a sneaking feeling this is a TV with the 24V going to the panel, and the LED driver is inside the panel.
That's how the AUO panels in the 40L1333DB sets do it, and they use a very similar arrangement of parts.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ah yes, I remember something like that now! IT IS SUCK BIG TIME.
https://www.badcaps.net/forum/showth...ght=LED+DRIVERLast edited by budm; 04-24-2015, 04:01 PM.Never stop learning
What a wonderful design, and yet another example of a product designed to be non-serviceable. What would be the problem with sticking the driver on the outside of the panel? No problem at all, but for some reason it's done this way.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Just to add: this is a Samsung panel, and yes, it's a piece of crap but it's a friend's Tv so agreed to try and fix it, thanks.Last edited by Dang; 04-24-2015, 04:46 PM.Comment
Samsung panel with LED driver inside the panel?
Can you provide the panel model number sticker? I would like to look up an info for it.Never stop learning
To fix you have to strip the panel
And get it like shown in the pic.
If you have full voltage across the inverter
Then you have to check for any blown led.
If all is fine its best to bridge the connections shown with solid wire and all should be well ..
Test it to see if any led's on verge of failing..Comment
Test it to see if any led's on verge of failing..Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
