LG PDP42G1 Plasma Lava Lamp Screen
  • rrsandmn
    • Apr 2015
    • Usa
    HELP!!!! Read through multiple threads but unable to find the answer that I need. I have a picture with oil slick, lava lamp look black blotchy areas that fade in and out. Also green, purple, red, blue dots moving about the screen.
    Tom66 guide talked partially about Timing but never could find the details on that. Any help would be appreciated.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: LG PDP42G1 Plasma Lava Lamp Screen
    Help us help you... Pictures of your boards and chassis?
    • capkid
      • Oct 2010
      • 1339
      A pic of the panel defect would also be helpful.
      LG Plasma Mal-Discharge Correction Service
      • mmartell
        • Oct 2013
        • 3189
        Sounds like Z sustain. Unplug power to that board and if symptoms are exactly the same that's your likely problem.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Zelek11
          Panasonic Plasma screen interference on left half of screen
          by Zelek11
          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
          10-14-2022, 04:54 PM
