LG47LW450U Not powering up correctly
  • nogger
    • Aug 2010
    • 190
    Hi all, i normally repair PSU units (all types) on the bench & rarely get to see a complete TV but this week someone dropped an LG LED tv in that they said wouldn't start up. Not having much experience of LED TV drive circuit's i would appreciate some advice.
    The PSU number is; EAY62169801 (pics attached) & i couldn't find a circuit anywhere (typical LG) . I did find a training manual for the 55LW5600 model which showed almost identical PSU (even down to the component refs). Has anyone a circuit diagram for this PSU
    Ok, i found that on power up, the standby LED is on, & the 3.5v standby is ok. On startup, the LED goes to white then goes off & the 12v & 24v come on ok. The voltage to the LED Drive though is only at 35.9 volts (screen never illuminates) & this is where i am unsure. The training manual says (for the 55LW5600) that the Drive voltage should be 56 volts going to 63 volts. The 35.9 v that i am seeing seems way too low to me (it never changes even with the LED strips unplugged). Also i monitored the DRV_ON pin from the mainboard & it never ever went high to 3.5v just sat there at almost zero. I forced the DRV_ON by connecting to the 3.5v line & the Drive voltage never changed from 35.9v
    To be honest i'm not even sure if there's a fault on the PSU & the main board because when i go to switch the TV off the front panel LED goes to RED but then immediately goes white & then off as if it's switched itself on again, strange. Also , at no time do i seem to get a DRV_ON signal from the mainboard.
    Anyone any thoughts ? is the drive voltage way too low at 35.9v , anyone got a circuit for this PSU ?
    Any assistance appreciated.
    Graham
  • nogger
    • Aug 2010
    • 190
    Re: LG47LW450U Not powering up correctly
    Anyone ?
      The LED drive Voltage may have drop down due to the protection circuits kick in due to open connection to the LED backlights.
      You need to put the meter to connector and see if the Voltage did jump up high (>50v) and then drop down to 35V or not.
      Bad LEDs or open connections are the common failure in LED backlights TV.
      • nogger
        • Aug 2010
        • 190
        Budm. the voltage is exactly the same when the LED's are connected. It's always 35.9v regardless & never peaks above that.
          Can you check DCV between chassis and the LED+ pins on the connectors P202, 203 when power switch is activated?
          • nogger
            • Aug 2010
            • 190
            Budm, thanks for replying.
            I'm pretty sure i did this already & the voltage just goes to 35.9v but i will check this in the morning again.
            Graham
            • nogger
              • Aug 2010
              • 190
              I checked this again & confirm that regardless of whether the LED's are connected or not the Drive voltage on switch on goes to 35.9v & never goes higher.
              Graham
              • nogger
                • Aug 2010
                • 190
                Anyone any ideas ?
                Graham
                • nogger
                  • Aug 2010
                  • 190
                  I just powered up this PSU on the bench & again forced the standby & LED Drive signals high & this time the LED drive went to 63 volts for approx 4-5 seconds before dropping so it would seem the PSU is ok. When i popped it back into the TV & leaving the main board disconnected i again forced the Standby & LED Drive signal high & i got backlights on !
                  I guess this means the PSU is ok then & it's possibly a main board issue. I need to check the LED illumination to see if there's any uneven illumination but i guess if not then it's a mainboard issue ?
                  More testing & updates to follow
                  Graham
                  • nogger
                    • Aug 2010
                    • 190
                    I popped the PSU back into the TV & removed the link forcing standby on but left the link forcing LED_DRIVE connected. Powered up & again backlights came on. The drive voltage peaked at 63volts & dropped back to 52v & the LED's stayed lit. Next i took readings from chassis gnd to each of the metal rivets at the top of the PSU (see images) which represent the test points for the end of each diode chain. (El62 to El69 & El70 to El77) & therefore the voltage drops across each chain. I measured the voltages at each of the rivets (see attached ph0to of test results written on the page 56 of the LG LED training manual mentioned earlier). You can see that the voltages after the LED's came on are all around 1-1.3 volts with the highest being 1.42. According to the training manual the voltage drop across each diode is 6.14v so the voltages look good to me , anyone think different ?. If i had a faulty LED open circuit then i would think the voltage would be zero as they are wired in series & if shorted then a diode drop higher ?
                    Next i removed the link forcing the LED_DRIVE on , switched on & again no backlights, LED Drive reading 35.9 as before . I monitored the Drive_ON signal coming from the main board & it NEVER comes so i am beginning to think this is a mainboard issue . I noticed that when i apply power , the front panel LED faintly glows RED, fades away & then glows bright RED again before fading to WHITE & then BLACK at which poiint the TV is switched on. If i touch the touch btton to switch it off it goes back to RED , then WHITE then goes off again so it isn't6 actually switching off properly & keeps trying to start up.
                    Guys, your thoughts /opinions on the above are welcomed, anyone else think it's mainboard & from the readings above do you agree the LED's must be ok ?
                    Graham
                    • nogger
                      • Aug 2010
                      • 190
                      No One ?
                      Well i have ordered a main board anyway so fingers crossed .
                      Graham
                      • emilios87
                        • Mar 2015
                        • greece
                        Hello, i have the same problem, did you fix it with changing the main Board?
                        • ajlockhart
                          • Apr 2018
                          Graham, did you manage to repair the TV?
                            • 12206
                            • U.S.
                            Sometimes a duck is a duck, if the mainboard isn't sending drive_on signal, probably need a new mainboard.
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              I think what is happening here is what we have been seeing regularly with these LGs. The BGA chip is not making proper connections on the Main Bd. and so removing the Main Bd completely from the TV and using a Hot Air station at 350C for 10 mins at a moderate air flow of 4 on the speed control, heat the BGA chip and let it properly cool on its own. Adjust the air flow sufficiently such tht other SMD components do not blow off the board. This will fix your TV. BTW I have done this process about 4 or 5 times already and no call backs thus far, some since 2 yrs ago. Good Luck.
                              • H-B
                                • Mar 2014
                                • Sweden
                                Please read the info from this guy! Super!
                                https://alpengeist-tvrepair.blogspot...-clicking.html
                                • valvashon
                                  LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                  by valvashon
                                  The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                  Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                  11-24-2024, 12:08 PM
                                • DynaxSC
                                  ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                  by DynaxSC
                                  I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                  Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                  Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                  The behaviour is also really very strange, i.e.:
                                  • The disk shows always up in BIOS - so it is recognized, so far so good
                                  • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                  02-23-2025, 01:33 PM
                                • DarKHawK
                                  Asus 2021 ROG Strix G17 G713 not powering on and not charging.
                                  by DarKHawK
                                  I have an Asus 2021 ROG Strix G17 G713 that is not powering on and not charging. Board number is G533-6050A3250201.
                                  When plugged in, I found that the 3.3v/5v regulator was getting extremely hot, so I removed, next I found a short on the 3.3V rail. Removed the two 3.3v mosfets and found one of them shorted, but still the short on the rail did not clear. Then I injected voltage at that rail, and found out that U60400 the 2.5v rail was also getting hot. Removing it changed the short from 0 ohms to about 5-6 ohms, then I remove a bunch of other suspect components but that did...
                                  07-11-2025, 05:24 AM
                                • serious_electron
                                  Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                  by serious_electron
                                  Hello Everyone!
                                  I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                  06-28-2025, 02:57 PM
                                • ShadowAi12
                                  ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                                  by ShadowAi12
                                  I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                                  • The board enters a "ready to power on" state after plugging in the PSU.
                                  • Pressing the power button increases power draw.
                                  • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                                  Measurements:
                                  (taken after pressing the power button, while the board is attempting to start)
                                  • H_SKTOOC#
                                  06-11-2025, 01:05 PM
