Samsung LN40B500P3F
  • pansatdishman
    • Jun 2013
    • 110
    Samsung LN40B500P3F
    Hello all,
    I have a Samsung 40 LCD, I bought this thinknig it was a power supply issue, so I changed all the big capacitors,
    What happens is when you plug it in all that happens is the red light turns on you hit the power button on the tv or remote nothing happens, just stays a solid light
    so when i unplug the cord going from the power board to the input board, the screen lights up lcd,
    how do i fix this thanks?
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung LN40B500P3F
    if backlight turns on without the mainboard connected.
    You'll need to repair or replace the mainboard.
    • pansatdishman
      • Jun 2013
      • 110
      wheres the mainboard? thanks
      • truep
        • Aug 2010
        • 373
        The input board you unplugged.
        • pansatdishman
          • Jun 2013
          • 110
          the one with the hdmi plugs and coax and rca plugs? thanks
          • vinceroger69
            • Mar 2012
            • 6714
            yes thats the one is there a sticker with a part number on it?
            • newtothis
              • Mar 2013
              • 1556
              • england
              If you don't know which number to use take a picture and we will point you in the right direction
              • pansatdishman
                • Jun 2013
                • 110
                it says bn41-01276b in white on the board
                • pansatdishman
                  • Jun 2013
                  • 110
                  heres the board i livre in canada wheres the best place to get it?
                  • Terryfictv
                    • Mar 2011
                    • 124
                    P/N is on the bar code sticker = BN94-02746Y
                    • pansatdishman
                      • Jun 2013
                      • 110
                      thanks where can i find this board?
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        Those boards are quite rare.
                        • pansatdishman
                          • Jun 2013
                          • 110
                          can this board be fixed?
                          • Michael Long
                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                            by Michael Long
                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                            Dead / No Power / No Standby Light results after power company had three
                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                            09-13-2022, 06:55 AM
                            09-07-2024, 05:50 AM
                          • Nairolf
                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                            by Nairolf
                            I have a Samsung DM32D display.
                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                            Here’s what I have tried so far:
                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                            Yesterday, 03:47 AM
                          • Kaar3l
                            Samsung QLED QE65Q7FNAT only standby light
                            by Kaar3l
                            TV: Samsung QLED QE65Q7FNAT
                            PSU: BN4400940A
                            MB: BN94-12832K
                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                            09-24-2024, 01:35 PM
                          • marcinq
                            Samsung UE60KS7000 No Standby Light
                            by marcinq
                            I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                            I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                            05-26-2025, 11:36 AM
