Can a bad Y sustain or Y driver boards damage the plasma panel?
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I got my hands on not functioning TC-P50S30 Panasonic Plasma. The TV would not turn on and I was getting 7 LED flashes, which most people say is bad SS (Y-sustain) board. Sure enough it was shorted out, but I did not check on the Y drivers. I ordered online repair kit, re-soldered the parts, short went away. Put everything back, turned the TV on and nothing. 7 LED flashes again. The boar shorted out again, so I assumed the drivers are bad as well. Not worth the money anymore.
    I want to sell the panel, but I have never technically seen it on/working, so I cannot say with 100% certainty that it works. It is not cracked or anything, but I want to make sure that the panel cannot be damaged by other means, like shorted driver boards. Can it? Would I be most likely OK selling it as functional?
    Re: Can a bad Y sustain or Y driver boards damage the plasma panel?
    The panel is a solid state gas discharge tube, very hard for the sustainers to damage it. But, it is possible the panel is bad in itself due to a micro crack on the edge or damaged ribbon cables. This is a very rare fault on Panasonic sets, but something worth watching out for.
    I doubt you'd have much luck selling the panel - they are pretty solid devices that rarely fail, at least on Panasonic sets.
    • R_J
      • 9588
      We did have some Panasonic panels thet were bad, If you looked over the panel with a magnifier you could see one tiny black spot, (shorted plama cell) that would short a new buffer board in 2 sec.
      • newtothis
        • Mar 2013
        • 1556
        • england
        Tell that to a kid with a Wii remote :P lol
        • tw2005
          • Oct 2011
          • 6458
          Why don't you fault find it a bit more to get a better idea on what's going on.
          If the SD/SU boards are ok then it would be reasonably safe to assume the panel is ok as I find if these are powered with a cracked /shorted panel the buffers go. For the 2010 models I found it was the SD that would be dead.
          The repair kits are rarely a 1 size fits all.
          I've done the same SC board and it was $4 in parts 4 IGBTs. Sounds like your board had more failed on it.
          If you have a multimeter I'm sure we can at least work out what went wrong.
          had you fired that SC board up using the SC50 jumper (sd/su bypass) and the board failed then you'd be 100% certain something was missed on the SC.
          If we find the SD/SU are not shorted that too would suggest failed SC repair.
          Potentially all these need replacing D401 D421 Q441 Q402 Q403 Q422 Q423 Q531 IC502
          • SurrealMustard
            What parts can be salvaged from a plasma with a damaged display panel?
            by SurrealMustard
            I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
            03-09-2025, 08:29 PM
          • osrex
            LED DRIVER KEEPS DYING
            by osrex
            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
            i have no datasheet at all for the LED lights, all i have is its length.
            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
            05-05-2025, 03:36 PM
          • howardc64
            LG 49UJ6500 LCD panel lighter band that goes away
            by howardc64
            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
            02-19-2023, 12:13 AM
          • triplefour
            SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
            by triplefour
            TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
            tcon is built into mainboard.
            Only one cable goes to panel boards.
            there is a cable from one panel board to the other that links them.
            cost cutting measure that results in us having harder time to diagnose.
            removing the link to the second panel board allows TV to stay on with stable backlight but no image.
            used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
            07-28-2022, 07:59 PM
          • Storyteller12
            QN55Q60R Service Menu Panel Help
            by Storyteller12
            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
            01-13-2024, 01:57 PM
