37LB30Q Proscan LCD TV Colors are inverted (Black to white)
  • nightwindzero
    • Mar 2015
    • 9
    Model: 37LB30Q
    Branded:Proscan
    2008-10-11
    Symptoms:
    The tv had a solarized image to start with so as much research as I could manage, I replaced the T-conn board.
    Now after putting it all back together, the colors are inverted. (Please see pictures)
    I've been through the service menu thread for Proscan so I don't think there is a service menu that I can find on this TV.
    Any suggestions are welcome.
    Thankyou!
  • selldoor
    Slow Learner
    • 7870
    Re: 37LB30Q Proscan LCD TV Colors are inverted (Black to white)
    Is the "inverted" picture something we should recognise?
    Perhaps pictures shoeing the part numbers of each Tcon and barcode would help
    • nightwindzero
      • Mar 2015
      • 9
      So sorry, The inverted image is one of the standard Mac backgrounds. I didn't even think about describing it.
      I'm attaching the inverted color image of the picture. The icons on the launchbar should be recognizable now, at least the Google Chrome one for me.
      Thanks for responding!
      • selldoor
        Slow Learner
        • 7870
        Ok - never used a Mac - did you see this for Win 7 you need to read the comments to see how he did it. Magnify then alt i IIRC - Maybe there is a way of doing this on a MAC
        Is the output OK on a different screen?
        https://www.youtube.com/watch?v=WLvUOvlZd8o
        • selldoor
          Slow Learner
          • 7870
          Duh! sorry it must be you just posted a picture?
          EDIT or did you just photoshop the original?
          Here you go - perhaps ---- http://www.wikihow.com/Invert-Colors-on-a-Mac
          • nightwindzero
            • Mar 2015
            • 9
            EDIT: I just photoshopped the original picture. Though I did just try what you suggested and it works!
            Ok, So to clarify, this isn't just a problem with just the VGA input, I have the same problem with antenna and even the TV menu seems inverted as well.
            I don't have an HDMI connection to test it with right this second.
            To do that on a mac you (I used a windows keyboard for this) press and hold CTRL-Windows-ALT and then press 8 on a mac.
            For the windows he used an accessibility on magnifier, it's just a checkbox to invert colors.
            So Thankyou very much for what appears to an AWESOME workaround. A software solution is not something that occurred to me.
            Any idea for what might be wrong with the LCD hardware?
            THANKS!
            • selldoor
              Slow Learner
              • 7870
              Ok desperate hope that you had pressed some buttons in error.
              Did you mean the factory resets list?
              In my long list of getting into SMs there is one headed RCA GE Proscan
              in this post
              https://www.badcaps.net/forum/showpo...3&postcount=46
              Dont know if any of them work
              • nightwindzero
                • Mar 2015
                • 9
                As an FYI, that is an AWESOME list. But I already went through that and none of the "RCA GE Proscan" codes appear to work for my TV. I did try them again, but still not working.
                • selldoor
                  Slow Learner
                  • 7870
                  Ok - I am out of ideas for now - other than making sure your new card is an EXACT replacement - otherwise wait for others to chime in. - good luck
                  • selldoor
                    Slow Learner
                    • 7870
                    No one? Another service menu code tp try Menu + 1147
                      • 31061
                      are the oncsreen menu's inverted, or just the image from the computer?
                      • nightwindzero
                        • Mar 2015
                        • 9
                        Tried Menu 1147, not working.
                        The menu on the Television is also color inverted.
                        All images on the Television are color inverted, in retrospect I should have left the computer out of this.
                        If I use Red/White/Yellow plugs, or image from an antenna the colors are inverted.
                        Thanks!
                        • selldoor
                          Slow Learner
                          • 7870
                          Did you check the barcode labels on the Tcons - maybe the new one is faulty? can you return it.
                          • nightwindzero
                            • Mar 2015
                            • 9
                            Hi Guys,
                            Thanks for saying to check the barcode, the boards look identical so I completely didn't check. So I put the old one back in and colors look fine but the screen is "solarized", which was my original problem.
                            The new t-conn board, did fix the "solarized" problem, everything was perfect but the colors were inverted.
                            Spoke with www.wisiny.com and they said the board should be compatible, but I'm asking for a new one.
                            Old Board:
                            T370XW02 VO CTRL BD
                            06A12-1A
                            US-5537t03c05-83c-4018269-t056x-01
                            Ordered T370XW02 V0 06A12-1A AUO 55.37T03.C05 T-Con Board
                            New board:
                            T370XW02 VO CTRL BD
                            06A12-1A
                            US-5537T03034-813-4016044-T01IQ-05
                            Thanks!
                            • selldoor
                              Slow Learner
                              • 7870
                              Let us know how it goes - I think maybe the AUO and US means they are for different
                              panels? AUO is certainly and panel manufacturer
                              • sgcampion
                                Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                                by sgcampion
                                My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                                In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                                10-24-2023, 09:39 AM
                              • hcinne
                                Dell G15 ryzen edition black screen 2 amber 1 white
                                by hcinne
                                I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                07-23-2024, 07:56 AM
                              • ojmc
                                Hisense 65H6570G - Color inverted after replacing LED backlight
                                by ojmc
                                Background:
                                • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
                                • I replaced all 6 of the backlight LED strips with these replacements: amazon
                                • The TV worked again perfectly for ~2 weeks.
                                • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
                                10-17-2024, 02:29 PM
                              • Raulnn
                                TD Systems K50DLG12US half black and half white screen
                                by Raulnn
                                good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                01-20-2024, 04:49 PM
                              • Ihandyrepair
                                sony 55X850D black screen no front white or red led light.
                                by Ihandyrepair
                                Hi guys
                                strange one
                                I have a dead Sony 55X850D
                                when plug in, black screen, no front white or red LED, no back light no screen
                                Voltages I get
                                3.3v LD/power and main board
                                reg 12V
                                reg 19V
                                3.3v on power on pin
                                no Tcon on
                                no tcon 12v
                                no BL_on
                                I do get BL_ERR 2.0v
                                I tried to bypass it by ground it but still get same symptom
                                I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                                or is possible the chip next to...
                                08-07-2024, 04:58 AM
