panasonic tx-p50s10b
  • paulstef
    • Dec 2013
    • 724
    Re: panasonic tx-p50s10b
    GOOD!
    The uCs need 3.3V. If they don't have it they won't do anything.
    Checking the schematic....
    In the meantime you could power off everything and see if you have a short from this 3.3V line to GND.
    • paulstef
      • Dec 2013
      • 724
      Mmh, ok, THIS 3.3V is switched. The signal to turn it on comes from another uC.
      We need to check first IC5480 input and output voltage.
      • ronhayes
        TV Engineer
        • Mar 2014
        • 458
        It is not shorting to GND.
        • paulstef
          • Dec 2013
          • 724
          Nevermind. This 3.3V signal depends on another signal. See previous post.
          • ronhayes
            TV Engineer
            • Mar 2014
            • 458
            Sorry Paul
            This IC was on the other side of the board.
            I am getting 4.25v on pin 7 and 0.24v on pin 8 of IC 5408.
            • paulstef
              • Dec 2013
              • 724
              Measure resistance from pin 8 to gnd (turn off power before).
              This chip, according to the block diagram on page 30, should create 3.3V from the 5V standby voltage. It doesn't so it's possibly either defective or there is too much load on the 3.3V output.
              It also does some other stuff and I don't know if any wrong signal or shorts or anything on the other pins could affect the 3.3V regulator.
              • ronhayes
                TV Engineer
                • Mar 2014
                • 458
                It is 03.3 in the 200 range checked with two different meters both reading the same.
                • paulstef
                  • Dec 2013
                  • 724
                  You mean 3.3Ohm on the 3.3V output pin 8 to ground? That's too low. Ideally we would now try to isolate the pin. :-D
                  You see that from pin 8 there is one trace going underneath the chip and goes then to a via to the other side of the board (unless it's a multilayer board, I don't hope so). Obviously you cannot cut a trace on this side. So you need to find the same via on the other side and then there is hopefully only one trace going from that via. That trace you would need to cut. Pin 8 is then isolated and you can you determine if the 3.3Ohm comes from the chip itself or from somewhere else.
                  Actually not difficult.
                    I have had that Panasonic multi-voltage IC fail on a PZ80 before. It generates some reset signals too, plus has over-voltage comparators... It's difficult to get hold of as it's a custom Panasonic IC. One supplier in Italy @ £10 each incl postage.
                    In my case the IC was bad because of a power surge through the HDMI ports, it had damaged one port and I guess the surge current had propagated through to other parts probably through the ESD protection networks, other damage made the board unrepairable (I replaced the IC but it failed immediately due to a shorted load, no current limiting...)
                    • ronhayes
                      TV Engineer
                      • Mar 2014
                      • 458
                      I see what you mean Tom.
                      I will have closer look at the ports tomorrow Tom.
                      I think my best way to go with this one is maybe a replacement board, depending on cost.
                      The problem with these sets is of course are they worth the cost of the repair due to the age and cost of new TT'S these days.But If I can locate a replacement board for the right price then maybe I will carry on maybe.
                      • ronhayes
                        TV Engineer
                        • Mar 2014
                        • 458
                        Hi Paul/Tom
                        Having a close look at this board i cannot see any visible damage near any of the ports although that doesn't mean there isn't any, and checking to see where the track goes underneath the IC is very difficult and most of the tracks are so close together on both sides of the board and and going by the poor state of my eyes these days, I think it would be better to see if i could source either a replacement IC or complete board which ever would work out the cheapest. The only problem with changing the IC is would this bring it back to life or not would be a gamble?
                          Well, the picture performance of a good Panasonic plasma is very good, so I would say yes, they are worth saving, but it obviously depends on what you want to do. If it's a customer's TV, they probably won't bother with the repair... 6-7 year old plasma TV, even if it's better than 99% of the other TVs out there...
                          • paulstef
                            • Dec 2013
                            • 724
                            We could at least try to find out if it's this chip or not. Because if it's not than online troubleshooting will be become so difficult you are really better of buying a new board.
                            I've seen that IC for just a few dollars somewhere, have to find the link.
                            I'll try to find that trace on the other side for you...
                            • paulstef
                              • Dec 2013
                              • 724
                              Bad news. It's definitely a multi-layer board. The trace goes from pin 8 of IC5480 underneath the chip and to a via. The same via is connected to C5513 on the other side nowhere else. That means ST3.3V must be distributed on an inner layer.
                              Since you said your eyes aren't that good anymore I assume you don't want to try slightly lifting pin 8 from the board, right. :-)
                              There are some other things we could try but I think it's getting more complicated now.
                              • ronhayes
                                TV Engineer
                                • Mar 2014
                                • 458
                                Paul
                                Just out of curiosity i thought i would have a go at lifting that leg using a needle and fine tip soldering iron and i managed to lift it ?
                                • paulstef
                                  • Dec 2013
                                  • 724
                                  Paul
                                  First I would remove the solder from that pin with solder wick. Then yes you could use a needle and slightly forcing it up while heating the pin/pad.
                                  Don't lift it up too much otherwise you may break the pin when pulling it down again.
                                  You should then be able to measure resistance again and determine where the 3.3Ohm come from.
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    Paul
                                    I have checked it and the it appears the 3,30 ohm is from the track and not the 8 leg but it is a slight difference now it is reading 3.10 ohm as apposed to 3.30 ohm.
                                    • ronhayes
                                      TV Engineer
                                      • Mar 2014
                                      • 458
                                      Was just wandering could you install a A board from a 42" panasonic with the same model number and go into service setup and change it for a 50" or must the Aboard be from a 50" only ? As the only ones i have seen so far are for a 42".
                                        You can but you would have to swap over the panel data flash or the panel might not work properly (maldischarge) this will involve surface mount soldering
                                        • paulstef
                                          • Dec 2013
                                          • 724
                                          3.3V goes to several places from there.
                                          Does the short on the trace still exist when you remove the cable that goes to the power button,IR sensor assembly?
                                          That's supposed to be connector A1 on the A board.
                                          See page 31 of the SM.
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
                                          • aa10aa10
                                            Panasonic Toughbook CF-33 mk1 BIOS repair
                                            by aa10aa10
                                            Good day,
                                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                            01-21-2025, 06:13 AM
                                          • Mnawar27
                                            Panasonic CF-H2AU24EF3 bios locked
                                            by Mnawar27
                                            Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                                            I need help to remove it,
                                            thankyou all.
                                            SN; 2FKCA26876...
                                            11-16-2024, 08:00 AM
