panasonic tx-p50s10b
+ More Options
Posts
  • paulstef
    • Dec 2013
    • 724
    Re: panasonic tx-p50s10b
    Measure again the voltage on the reference pin and STB_IN.
      It is important not to connect the main board if you are fiddling with the reference until you are sure the PSU is working, this is to avoid a high standby voltage damaging the main. I have seen 12V come out of a 5V converter with failed feedback, this will obviously not do much for a board where most components will have an absolute maximum operating voltage of 5.5~6V.
      • paulstef
        • Dec 2013
        • 724
        I didn't even think about this but yes you're so right. There is also the uC on the PSU directly connected to STB_IN 5V... Better be careful.
        • ronhayes
          TV Engineer
          • Mar 2014
          • 458
          Have checked the ref pin it is now 2.30v
            What is output voltage?
            • ronhayes
              TV Engineer
              • Mar 2014
              • 458
              3.80v
                Ok, that is not good then, I think you might have to order a replacement TL431, preferably an exact replacement.
                • paulstef
                  • Dec 2013
                  • 724
                  The relationship almost hasn't changed... 4.73/2.8, or 3.8/2.3... Weird.
                  From here I think you would really need a scope, checking signal on cathode of the TL431 (should be non conducting at 2.3V), the optocoupler input and output, duty cycle of the controller IC...
                  There is only so much you can do with a multimeter.
                  What's the DC voltage on the cathode of the TL431 measured with your meter?
                  • ronhayes
                    TV Engineer
                    • Mar 2014
                    • 458
                    Maybe i am reading this all wrong !!
                    I have just measured volts on the IC551 (TL431C ) and what i am getting is pin 1 ref =2.30v pin 2 anode =0v pin3 cathode = 3.80v
                    Have not yet located my scope think i may have stored in the loft.
                    • paulstef
                      • Dec 2013
                      • 724
                      Ok, but what voltage is STB_IN, the power supply for the uC?
                      • ronhayes
                        TV Engineer
                        • Mar 2014
                        • 458
                        Don't know if this will give you any clues but now i have installed this TL431C i get at pin 5 of P7 steady 4.80v with power button pressed in then slowly decreasing volts from 4.80v when power button released. pin 9 of p7 i get 4.58v then 0v when power button pressed. and pin 9 of p25 getting 4.80v steady with power button pressed then slowly decreasing volts from 4.80v when power button released.
                        This is with the plugs disconnected from the A board ?
                        • paulstef
                          • Dec 2013
                          • 724
                          Pin5 of P7 and pin9 of P25 are the same signal, the switched STB voltage (5V). No need to measure both.
                          Anyway... Now we gained 70mV , up from 4.73V to 4.8V. No progress so far.
                          When the mainboard is connected, does the voltage at pin 5 of P7 remain ON even after releasing the push button?
                          • paulstef
                            • Dec 2013
                            • 724
                            I think I would try to force the PSU on by activating the signals PANEL_Main_ON and F_STBY_ON.
                            You would need to connect the 4.8V to these signal inputs on P7 and P25. Without the A-board of course.
                            • ronhayes
                              TV Engineer
                              • Mar 2014
                              • 458
                              I get 4.80v at that point.
                                @ron, are we sure your multimeter is good?
                                Could you check against a known good reference? Or use another meter?
                                • ronhayes
                                  TV Engineer
                                  • Mar 2014
                                  • 458
                                  On pin 5 of p7 i get a steady 4.80v when power button pressed then when power button depressed it drops to less than 1v and slowly decreases from that 1v.
                                  So would i link from pin 5 to pin 6 on p7 and from pin 5 of p7 to pin 11 on p25 or from pin 9 of p25 to pin 11.
                                  • ronhayes
                                    TV Engineer
                                    • Mar 2014
                                    • 458
                                    Tom
                                    I have a couple more cheaper type meters than my M92A one of them is a Hilix DT-830B
                                    I have just put a new battery in it and tried that one and was getting 5,21v at pin 5 p7
                                    (st-by 5v)
                                    I just never thought to try another meter maybe it would be time to invest in a new multi meter,
                                      Certainly, given that it appears to have put is on the proverbial "wild goose chase", as it appears nothing was wrong with the power supply! But, you live and you learn
                                      • paulstef
                                        • Dec 2013
                                        • 724
                                        Yes, and there is probably a sequence to turn them on.
                                        Both signals go to the uC IC701 which will then activate RLY_MAIN and RLY_RUSH.
                                        I'm assuming /RLY_MAIN turns on first and then /RLY_RUSH, therefore first will close relays K604 and K605 and then K602.
                                        Is RF601 the white big resistor near the relays?
                                        • paulstef
                                          • Dec 2013
                                          • 724
                                          You turn on one signal and observe what happens and then the other.And post the result here. Like which relay turned on when and which voltages you get on the different connectors.
                                          Be careful :-)
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
                                          • aa10aa10
                                            Panasonic Toughbook CF-33 mk1 BIOS repair
                                            by aa10aa10
                                            Good day,
                                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                            01-21-2025, 06:13 AM
                                          • Mnawar27
                                            Panasonic CF-H2AU24EF3 bios locked
                                            by Mnawar27
                                            Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                                            I need help to remove it,
                                            thankyou all.
                                            SN; 2FKCA26876...
                                            11-16-2024, 08:00 AM
