LE40M87BD restarting
  • sordids999
    • May 2013
    • 2152
    hello
    tv keeps restarting itself voltages seem ok read it could be cold solder joints tried that tv worked all evening,but now this morning testing it again and the tv has restarted and is stuck in a loop of doing this
    just wondering if anyone has come across this fault ?
    thanks
    Re: LE40M87BD restarting
    On these it's usually the main board at fault. cold solder under processor (BGA) or bad cap near processor.
    • sordids999
      • May 2013
      • 2152
      ok thanks ill check now
      • sordids999
        • May 2013
        • 2152
        tom do you mean under the metal heatsink with the caps etc ?
          Yeah. The shield is soldered down; Not done one myself though, so can't be sure on the exact parts that fail.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Aye--Could be the two 1000uF 10V caps under the tinwork cover by the processor.
            There's a row of 100uF SM Caps by the power-socket near tinwork that can cause issues too...
            --When done--you must replace tinwork--or the processor overheats--there's dead-toad pad from two chips to the tinwork.....
            TELEFIX
            • sordids999
              • May 2013
              • 2152
              thanks alastair i have highlighted the caps do you mean those two and can you point me to the 100uf caps please
              thanks
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Yup--Those are the 1000uF caps...
                The 100uF ones are the three between the socket and the tinwork, (There's one pink-top poly cap-thats usually OK in the row) plus the couple that run at right-angles to that row and along the bottom of the tinwork--All can be suspect....
                Bung a 'Scope on them--You'll see horrible switching noise/ripple on 'em....
                TELEFIX
                • sordids999
                  • May 2013
                  • 2152
                  UPDATE:
                  Changed the 1000uf caps on the main board still restarting also went into service menu set ready to on and been working now for two days
                  Thanks to Tom for the pointer on the READY option
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Nice one
                      What the heck is the 'SET' function for. I am glad you and Tom figured it out.
                        The READY option appears to be some kind of watch-dog. If it is turned off, the set will reboot approx every 10 minutes. READY might get turned off by corruption to EEPROM. Very odd fault.
                          Thanks.
                          • noledud
                            • Dec 2013
                            • 413
                            • united kingdom
                            hi all iv just tried this and it kills the free view can anyone confirm this ?
                            • noledud
                              • Dec 2013
                              • 413
                              • united kingdom
                              the ready option i mean not the caps not tried that on this board but had n o luck with that in the past on the same board
                                Didn't kill the Freeview on other sets I've tried it with.
                                • noledud
                                  • Dec 2013
                                  • 413
                                  • united kingdom
                                  mines strange it would go off if ready set to ON
                                  Iv set mine to off and it no longer restarts but when its off the digital tv is "unavailable"
                                  strange but working thanks for the tip !
                                  • geofpt
                                    • Aug 2020
                                    • United Kingdom
                                    It's 5 years after the last post, but I had the same problem of restarting. After hours of searching and pondering changing caps that did not look damaged, I came across the READY ON solution and it works. If Tom666 is still out there "THX". Well played and figured out. At least I now have schematics which I could not find anywhere else.
                                    • Mirenia
                                      Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                                      by Mirenia
                                      got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                                      The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                                      If this happened once, then the laptop only runs for a few minutes until restart.
                                      This happens regardless while staying in windows or uefi or in a linux environment.
                                      At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                                      01-05-2025, 05:15 PM
                                    • corrize
                                      Best way to solder LVDS connector for beginner (and qfn) ?
                                      by corrize
                                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                      See the test :
                                      https://youtu.be/bNAzC-EvqHs?t=1767
                                      With hot air from bellow the board, that's...
                                      03-09-2023, 02:57 AM
                                    • myth77
                                      UV solder mask - high temp resistent, recomendation?
                                      by myth77
                                      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                      Is there any solder mask...
                                      03-28-2022, 04:04 AM
                                    • petemanuk
                                      BGA solder balls not connecting - help pls
                                      by petemanuk
                                      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                      11-16-2022, 05:21 AM
                                    • acedogblast
                                      by acedogblast
                                      11-02-2024, 05:13 PM
