Samsung LN46C540F2FXZC Main Board Swap?
  • jonadagi2
    • Mar 2015
    • 8
    Is it possibile to swap a main board from a 40" LN40C540F2FXZC TV into my 46 " LN46C540F2FXZC?
    Main Board problem was identified as follows:
    The power led blinks six times when I try to turn the TV on. I disconnected the main board to power supply cable and the backlight goes on. As per this thread, it would indicate that the main board is defective.
    Since this was a model exclusive to Costco and Walmart Canada, I'm having trouble finding parts for it. I've made a special request to Samsung Parts Canada, but judging by the other main boards on their site it will be very expensive. p/n BN96-16374A (Other boards are going for $228 CAD).
    There's an ebay listing for a main board for the same model, but 40" size: Model Code LN40C540F2FXZC. 40" Main board part no. BN96-14950A, for $70 CAD.
    At $228 +shipping +tax (~$273 CAD) I'm not sure it's worth it. $70 all in is worth it, but only if there's a good chance it will work.
    I've attached photos of the Model Labels and their respective main boards for comparison.
    LN46C540F2FXZC - Model Label - TV to be Fixed
    LN46C540F2FXZC - Main Board BN96-16374A - TV to be Fixed
    LN40C540F2FXZC - Model Label - Ebay Listing
    LN40C540F2FXZC - Main Board BN96-14950A - Ebay Listing
    If anyone has any idea if these two boards are compatible, please let me know.
    Thank you,
    Jon.
  • Terryfictv
    • Mar 2011
    • 124
    Re: Samsung LN46C540F2FXZC Main Board Swap?
    Research shopjimmy.com
    http://www.shopjimmy.com/samsung-bn9...c540f2fxza.htm
    Terry
    • jonadagi2
      • Mar 2015
      • 8
      Thanks, but Shop Jimmy was one of the first places I tried.
      Nothing comes up with my board or for my TV model 46" TV: LN46C540F2FXZC
      Since my board does not exist on their website there is no way for me to cross- reference to see if the 40" board is compatible.
      • newtothis
        • Mar 2013
        • 1556
        • england
        Most likely not as the firmware is made to drive a 40" not a 46"
        Possibly be able to swap firmware out mindya.
        Someone who has dealt with doing this should pop on and advise further
        • newtothis
          • Mar 2013
          • 1556
          • england
          http://www.tvserviceparts.com/BN96-15676A.html
          • jonadagi2
            • Mar 2015
            • 8
            Thanks for the replies.
            Man living in Canada really sucks as a consumer...
            Originally posted by newtothis
            Cheapest shipping option adds $41.
            Trying to return the old board for the Core Deposit credit would not be worth it due to shipping & brokerage.
            So, with exchange rate, the cost of a new board is $298 CAD + duty & taxes.
            • Asraf Atb
              by Asraf Atb
              01-27-2025, 05:02 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              Today, 08:34 AM
            • Lee M.
              Samsung UN75RU8000FXZA bad main board?
              by Lee M.
              When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
              11-08-2023, 07:46 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
