Samsung LN40B550 dark scenes (only) no contrast
  • mathog
    • Mar 2010
    • 2655
    We have an LN40B550 Samsung LED flatscreen and for some dark scenes, in some shows, there is practically no contrast. Ironically "Blacklist" is particularly prone to these. The thing is, in general terms, the color and grey scale calibration is perfect. When a grey scale image is fed in from a laptop through the SVGA port it is perfect. Similarly when this set of video test patterns is fed in through an HDMI connection from the bluray player (which has a youtube interface)
    https://www.youtube.com/watch?v=zTfGuO9chAk
    that is perfect too. These test images have a full range of greys in them though, from full black to full white.
    The issue seems to be that when a scene only uses the bottom 1/8th or 1/16th of the available grey scale range the contrast flattens out to nothing. Presumably some TVs must be able to render these better or they would never broadcast these sorts of scenes.
    These are being viewed in a dark room, so our eyes should be able to adjust to that range and see a reasonable amount of contrast even on that limited range. Which leads me to believe that the inherent contrast which was broadcast is being squished for some reason.
    Is there some control that can be used to address this issue? The standard contrast/brightness are not going to do that, because those are already correct for the whole gray scale.
    Current picture settings are:
    mode: movie
    backlight: 5
    contrast: 50
    brightness: 57
    sharpness:20 (greyed out)
    color:50 (greyed out)
    ting (G/R): G50/R50 (greyed out)
    advanced settings:
    black tone: off (greyed out)
    dynamic contrast: off (greyed out)
    gamma: 0
    color space: auto (greyed out)
    white balance (defaults)
    flesh tone :0
    edge enhancement: off
    Picture options:
    color tone: normal
    Digital NR: auto (greyed out)
    HDMI black level: low
    flim mode: off (greyed out)
    Suggestions???
    Thanks.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung LN40B550 dark scenes (only) no contrast
    Try BL = 8,
    Cont at 80-85,
    Bright to 45-50,
    Colour to 40
    TELEFIX
    • TortureGarden
      RCBS Chargemaster 1500 scale & powder dispenser
      by TortureGarden
      Good morning all.
      I have an RCBS Chargemaster 1500 combo electronic scale/powder dispenser that I have been using without issue for 15 years or more. I powered her up to do some reloading the other week and the LCD panel backlight & characters lit-up and then immediately, the characters faded-out, leaving just the backlight illuminated. I thought it may have been a one-off so, I tested again (and again...), with the same result.
      I separated the scale from the dispenser and disassembled the scale. Nothing obvious observed that could be causing the issue, caps look...
      02-06-2024, 07:35 PM
    • cloudy
      HELP - Contrast/brightness issue with subtitles on screen
      by cloudy
      Hi everybody
      Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
      Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
      Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
      It occours both on ubuntu and windows...
      01-01-2023, 05:12 PM
    • chronic519
      Optiplex 7070 absolute greyed out
      by chronic519
      Optiplex 7070 with absolute greyed out
      located the 16 pin Winbond, cannot locate any other flash chip.
      Assuming its on the SMSC SCH5555V-NU (cant find data sheet) (cant find board schematics).
      Hoping someone could point me in the right direction so I can upload dumps for cleaning.
      Thanks.
      03-07-2025, 08:34 PM
    • Xan03
      Sony Trinitron E450 bad contrast 15-20 minutes after turning on
      by Xan03
      I have this CRT monitor, a Sony E450 made in 2003, that has the issue of a quite bad contrast and washed out picture after powering it on, it takes roughly 15 or 20 minutes to improve considerably but even then black levels still aren't quite ideal. This is with brightness dialed in via test pattern and contrast at 100% to get acceptable light output levels.
      Since it does improve after a warm up time is there a good chance of this being caused by capacitors and if so, what part to recap first? As far as I'm aware the vertical deflection area is where caps are stressed the most but...
      01-25-2021, 10:43 AM
    • jorpec
      by jorpec
      Hi
      Thnaks
      01-23-2023, 10:37 AM
