Tnpa5063 in need of repairing
  • Rickig
    • Mar 2015
    • 112
    • England
    Any body out there repaired a tnpa5063 panasonic sc board?
    See a repair kit on eBay but it's in the usa.
    Could do with it being repaired or if someone has a replacement I can buy.
  • sordids999
    • May 2013
    • 2149
    • uk
    Re: Tnpa5063 in need of repairing
    https://www.badcaps.net/forum/showthread.php?t=41542
    this may help more
    • Rickig
      • Mar 2015
      • 112
      • England
      Thanks. This sort of electronic repair is beyond me. I need someone to repair the board for me. But thanks
        May want to ask GTVWatford on eBay - they do a lot of repairs of similar boards.
        • subwagon
          Repairing or replacing an LMB202E LCD Display
          by subwagon
          Hello everyone, I'm in the process of repairing a tabletop air cleaner, but am having difficulty repairing a failing LCD display.
          3 years ago I ran a soldering iron over the ribbon cable and got the entire display to come back to life. Unfortunately it gradually failed again but this time I wasn't so lucky at getting it to revive with heat.
          I believe that I may have gotten the ribbon too hot this time, so I'm looking for an alternative to an LMB202E. Unfortunately I am not having much luck. I did find an LMB202A, LMB202C, and LMB202D but I'm afraid the pin outs are...
          10-27-2023, 01:39 PM
        • chronic519
          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
          by chronic519
          Hello.
          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
          Found issue with a RAM block
          Replaced, green lines gone.
          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
          Used a good card to test and same results low errors 32+.
          I am just search for some form of command to do a full test on the GPU.
          I just ran the mats command with my good GPU and passed after roughly 40 min.
          The repaired one, ran...
          05-20-2025, 07:56 PM
        • h0m3w0rk
          Repairing a Music Store Professional GO! SUB 18A
          by h0m3w0rk
          I'm working on repairing a Music Store Professional GO! SUB 18A bass subwoofer, and I need some help troubleshooting an issue with the power amplifier board. The board uses an IR2153 driver and originally had two SLW20N50C MOSFETs. Unfortunately, these MOSFETs burned out. I replaced them with two TK20J60W MOSFETs; however, these also failed almost immediately.
          Here are some details:
          • SLW20N50C (original):
            • Rated for 500 V
            • Typical RDS(ON): 0.21 Ω
            • Continuous Drain Current: 20 A at 25°C (13 A at 100°C)
            • Pulsed Drain Current: 80 A
            • Avalanche
          02-27-2025, 07:42 AM
        • pastapoulos
          Repairing GIGABYTE RTX 3070 TI GAMING OC 8GB Rev.1.0
          by pastapoulos
          I picked up this non-working graphics card with the intent of repairing it. I don't know the details of its failure, but the card is in near-perfect cosmetic condition. It had never been opened before I started working on it.
          During my inspection, I didn't spot any obvious physical damage. However, when testing, I discovered the PCIe 12V line was open. I replaced the blown fuse and rechecked the measurements—no short circuits on the main lines.
          When I tested the card in a system, it prevented the PC from booting. I checked the main voltages,...
          11-22-2024, 08:57 AM
        • loko
          Tesla 13.7 body sculpt repair problem, need help with finding the thyristor marking.
          by loko
          Hello everyone.
          I have a device that is used to shape the human body muscels and burns fat. Works on the principle of electromagnetic impulses. One thyristor in side is shorted which has only this unknown mark on it ( QC230301 ). I can't find any information about it anywhere on the Internet. I tried to replace that thyristor with one of 1.6kv 800A and after 5min. of work he has burned out again, which means that he is probably weak. There is no schematic diagram on the internet, but that didn't suprise me because all the transistors and chips that are on the boards have their markings...
          10-27-2024, 11:31 AM
