Sharp LC-60LE820 LED Strip Repair
  • Ltank
    • Jun 2013
    • 776
    The TV does not come on. I bought a new Power supply but it still does not have a backlight and shuts down. I could not get a resistance reading on the wires to the backlight LEDs. I assume it open or to high a reistance for my meter Fluke 87 Ver3.
    I have tried to repair LED strips in the past with no luck. The LEDs are generally secured with some type of Heatsink glue that hardens and usually damages the strip when attempting to remove them.
    What is the best way to remove them?
    What Heatsink glue or epoxy should be used?
    Does anyone know what the correct or substitute part should be used?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Sharp LC-60LE820 LED Strip Repair
    When testing the LED strips--you'll get no reading using a meter if measured across the whole string.
    You can check each individual LED to find/see if they are faulty generally with a meter.
    LED's are not available separately, best you can do is use summit like the 1-2W LED's available on fleagay, in an appropriate package size...
    Cant even get whole strips either, they are just Not available.
    As to removal--depends on what type LED it is. Those under lenses are basically the LED chips themselves coated with the downconverter phosphor. Best bet scrape 'em off after breaking the lens bonding points!
    TELEFIX
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • Pipolups
      Corsair K70 LUX RGB dying LEDs
      by Pipolups
      Hi there !
      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
      10-08-2024, 11:58 AM
    • JayPoorJay
      Sharp 70' LEDs Spike 260v at start up?
      by JayPoorJay
      Hi all. This is my second thread. Have a bunch of questions.
      I got my hands on a 70 inch Sharp Aquos LC70EQ10U. Not working when I found it.
      I replaced the power board (found in eBay) and the TV finally produced an image. Reset it had image and sound.. Went from 2 slow and 2 fast blinks as a fault code to 1 slow 1 fast fault. Lamps or inverters according to the manual. TV is one now, at this moment (looks great w/ ZERO dark spots on screen) but it powering up and producing an image is unpredictable. 3 out of 10 times.
      There are 3 leads to the LEDs....
      02-01-2022, 05:04 PM
    • edugimeno
      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
      by edugimeno
      Hi There!
      I'm trying to help my friend who owns a restaurant be just bought.
      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
      It's stuck using, I guess, the 2 sided tape that comes with the strip
      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
      09-05-2024, 09:34 AM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
