LG 50PA4500 not turning on
  • supered
    • Mar 2015
    • 22
    Hello
    I am trying to fix a 50" Lg tv that had clicking and would not power on.
    I found this post
    https://www.badcaps.net/forum/showth...light=50PA4500
    And this is where I'm at.
    Clicking was constant on the power supply and by disconnecting Y-sustain the clicking stopped ( 1 click when powered up) and the red led on the main board stopped flashing, replaced Y-sustain and buffer boards (came as a set) and now the tv will still not power up but no constant clicking.
    With every thing plugged in I get red power led and red led on main board and a flashing green led on the logic board.
    Power supply with everything disconnected except power I get 0 volts Vs and 0 volts Va with everything connected 206 Vs and 55 Va.
    I tried jumping m-on and stby pin 1 & 3 as suggested in above thread and nothing happens.
    Any help would be appreciated.
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 50PA4500 not turning on
    the power supply will need the mainboard to turn on.
    WIth only the powersupply and mainboard connected does be tv turn on. Ie: no clicking and perfect vs va voltages?
    • supered
      • Mar 2015
      • 22
      With power supply and only the main board plugged in I get just 1 click and 206 Vs and 55 Va
      • Hamie
        • Apr 2014
        • 1383
        Ok well the powersupply and mainboard appear to be working.
        That's not to say that the powersupply isn't failing under load but that's doubtful.
        • Hamie
          • Apr 2014
          • 1383
          So unplug the ysus form the XMain and plug the XMain back into the power supply Does the tv stay on. Vs va voltages still good?
          • supered
            • Mar 2015
            • 22
            yes
            • Hamie
              • Apr 2014
              • 1383
              Ok now unhook the buffer boards from the ysus and power on.
              with the buffers unhooked locate the test point on the ysus for vsc (vscan)
              Power on. If the tv stays on, and the vsc matches the panel sticker it would suggest bad buffer boards.
              • Hamie
                • Apr 2014
                • 1383
                Also note the vsc voltage might only appear briefly when the tv is plugged in. Then slowly drop to 0.
                • supered
                  • Mar 2015
                  • 22
                  vsc is 150 vdc and vsc is not on the sticker but 150 is
                  • Hamie
                    • Apr 2014
                    • 1383
                    There should also be a test point for -vy.
                    Should match the panel sticker.
                    • Hamie
                      • Apr 2014
                      • 1383
                      Fyi
                      • Hamie
                        • Apr 2014
                        • 1383
                        -vy also located on ysus.
                        • supered
                          • Mar 2015
                          • 22
                          Are they measured to chassis ground and with the buffers disconnected
                          • Hamie
                            • Apr 2014
                            • 1383
                            Yes.
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              -Vy is measured across a component--often a cap or resistor (Depending on model specifics)--the board is marked with + and - symbols and (-Vy)...
                              V-ZBias is found on X-SUS board and measured to chassis...
                              TELEFIX
                              • Hamie
                                • Apr 2014
                                • 1383
                                Yip sorry my mistake.
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  No mistake there, Hamie--Most are measured to chassis--Its only the -Vy thats a floating-supply that isnt...
                                  TELEFIX
                                  • Hamie
                                    • Apr 2014
                                    • 1383
                                    Yeah I forgot he had already checked the vsc and we'd moved on to -vy
                                    • supered
                                      • Mar 2015
                                      • 22
                                      My stickers reads
                                      voltage settings: 5v/ Va:55v/ Vs:205v
                                      N/A / - 190v / 150v / N/A / 120v
                                      The reading i am getting as measured at the green resistors marked -vy and vsc
                                      is 75vdc
                                      photo of board
                                      http://assets.shopjimmy.com/media/ca...3201-top_1.jpg
                                      • Hamie
                                        • Apr 2014
                                        • 1383
                                        -vy should be -190 volts.
                                        • LGhost
                                          Samsung ue55d8000yuxxu turning on/off and clicking
                                          by LGhost
                                          Hello everyone! This is my first thread asking for help and I'm new here so please be nice
                                          I'm trying to repair a Samsung TV but not having much success so I've came across this forum and it seemed kinda nice and friendly. The TV is clicking on/off (relay) and I can't seem to put my finger on the issue. The image looks fine (since I can get a glance at the "Smart TV" logo when it boots). But it's just an endless loop of on/off. If I disconnect the mainboard from the PSU it stops doing the "clicking" sound but that's about it. I've already got a used mainboard...
                                          05-22-2023, 05:40 AM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • rustyanthony
                                          Toshiba 55UL610 - Constant Relay Clicking
                                          by rustyanthony
                                          Howdy,
                                          My stepdad said all it does is click. And he was right. No backlight, no standby light on the front. Just a steady click when plugged in. It's amateur hour on my end but I'm trying my best to learn via forums and Youtube. Below I'll list the things I've done thus far.
                                          1. I've removed the power supply board and cannot visually see any defects, expanded capacitors or cracked solder joints.
                                          2. Fuses test good.
                                          3. Bridge Rectifier(I believe thats what it's called) reads out 169 volts.
                                          4. 5 volt from PJ91 tests good.
                                          5. The relay only...
                                          09-22-2020, 08:08 PM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
