TX-L50EM6B shadowed screen on one side
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all been a while picked this up tonight
    TX-L50EM6B but sadly it has a half screen darker than other
    ive stripped it down and checked tcon and cables
    also usual tab bonds to no avail
    so can anyone shed any light on what I can do try etc
    picture below of problem this is an led tv
    thanks in advance
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: TX-L50EM6B shadowed screen on one side
    Please help on this issue
      If B/L is good on that side, probably panel is bad. It looks like a panel fault to me.
      • wreksta
        • Aug 2013
        • 508
        • england
        How to test bl per side mate didnt knw there. WAs 2 bl if
        panel can I fix it
        • newtothis
          • Mar 2013
          • 1556
          • england
          Looking at the image the backlight is working on the faulty side as I can see the writing clearly. A panel fault is not repairable
            panel can I fix it
            You will be able to see if the backlight is evenly lit across the screen by looking at the "black glow" (the glow from the screen when displaying a black image.) It should be approx. the same brightness.
            Panel faults usually can't be fixed as newtothis says...
            • newtothis
              • Mar 2013
              • 1556
              • england
              There is too much bleed across the centre to be backlights too
                Yea, that's my thought too.
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • ravi_1617
                  HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                  by ravi_1617
                  Hello to all ,
                  I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                  Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                  on external VGA port image is perfect /normal , Attached image...
                  07-25-2025, 12:07 AM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
