Lg Plasma wont always turn on. 50inch model 50PV250
  • lupofiasco
    • Mar 2015
    Hey guys,
    Anyone out there heard of this issue...
    One day Tv just stopped turning on. Every time I pressed the 'on' button on the remote the standby light on the bottom corner would turn off (as is it was about to turn on) but then the standby light would quickly go red again meaning its in standby mode.
    Few days later tried turning it on and it worked. Nek day same issue not turning on. Did a bit of research and thought it might have been some bad caps but they all seem to be in good condition. Took the power supply board to the electronics store and a kid there seems to think it would be the 'soft starter' and that one of the green caps might be bad.
    Tried calling Lg and they just told me to try a factory reset on the machine which I haven't done yet because its in pieces...
    Anyone had a similar issue?
    Heres a link to a folder with 6 images...
    https://www.dropbox.com/sh/4s5ieb9fp...0x7ayRoVa?dl=0
    Thanks in advance!
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • RdeveLabs
    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
    by RdeveLabs
    To all the members here...
    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
    05-05-2025, 04:59 AM
  • robante15
    Acer Aspire 4520 won't turn on after reboot
    by robante15
    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
    If I remove the...
    04-06-2024, 06:50 PM
  • canadaboy25
    LG 50PJ550 Plasma tries to turn on then turns off
    by canadaboy25
    Hey guys,
    I have a LG 50PJ550 plasma that will not power on.
    When plugged in, the relays click and the screen lights briefly before the relays click again and it shuts right down. It then tries starting up again before giving up and just sits there with the red LED on. Pressing the power button again repeats the process.
    During the moment where the screen is on, there is a slight fuzz that starts to go away as most plasma's do when they turn on. So i do not think it is a panel issue as I get a normal looking image for a split second.
    I have tested the...
    11-17-2020, 11:20 PM
  • masoksian
    Dell latitude e7470 not turn on .power buton on off and Run Power problem
    by masoksian
    I am dealing with the problem of turning on and off my Dell e7470 notebook.
    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
    The system does not turn on, there is no post.
    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
    The problem continues in the same way.
    I tried to turn on the Fn key, nothing came to the screen....
    02-15-2025, 12:08 PM
