Samsung UE-46D6207 - Horizontal lines
  • SaLexi
    • Mar 2015
    • Finland
    Hello!
    My Samsung UE-46D6207 has faint horizontal lines going from left to right as seen in these pictures. Also a white line on the bottom part of the screen:
    http://i.imgur.com/lM61O0g.jpg
    http://i.imgur.com/qMUqFQc.jpg
    The lines are stable, they are not moving or static. Knocking circuit boards, applying pressure etc. doesn't make a difference...
    What do you think, is this a broken T-CON or is the lcd panel going bad?
    Re: Samsung UE-46D6207 - Horizontal lines
    I'm afraid that does look like the LCD panel has failed, sorry.
    • SaLexi
      • Mar 2015
      • Finland
      Hi!
      I'm not saying you are wrong, but can you clear me what makes you think it's the panel instead of tcon? Do a failing tcon make static - not stable - lines and interference?
      Too bad, tcon would have been a simple repair
        T-con can't cause "regional" defects as it generates data for whole panel. If, for example part of RAM was bad on T-con, you would get corrupted pattern running across display, but asyour pattern is uniform and in one area, the panel is the cause.
        For panel fault, I'm specifically referring to the single/few pixel wide line running across the bottom of the display.
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • Rubenlily
          Samsung QE50Q67TAU - horizontal lines
          by Rubenlily
          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
          I'm no expert but I've done the tape...
          08-16-2023, 01:12 PM
        • arctor
          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
          by arctor
          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
          04-26-2025, 05:22 AM
        • x_orange90_x
          Samsung UN46C8000XFXZA Horizontal lines
          by x_orange90_x
          I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
          I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
          07-15-2023, 05:06 AM
        • porfyriadhs
          Tv Samsung UE50TU Horizontal lines
          by porfyriadhs
          Hello to everyone. I tried the tape method to by pass the on and off problem for the Samsung tv I mentioned. But unfortunately lines starts to appear. My question is if someone knows how to fix the lines problem...
          05-16-2024, 02:44 AM
