searching ACF tape
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4464
    • Italy - Milan
    searching ACF tape
    Hi, is there anyone that have made the little investment of buying an ACF tape coil to repair lcd screen's tab bonding issue and want to sell some meters to others? On aliexpress it is sold at 85 euros/coil. The soldering iron tip to heat the tabs costs approx. 5 euros per tip. Bye..
  • RetroComputingGrotto
    IBM LTO 7 Tape Drive - Dust Sensors??
    by RetroComputingGrotto
    I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
    I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
    09-19-2024, 01:54 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • triplefour
    LG 75UN8570AUD panel issue fixed with tape.
    by triplefour
    I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
    add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
    07-17-2023, 10:22 PM
  • chth96
    How can I test coil whether it is really broken or not?
    by chth96
    I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
    I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
    I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
    I want to replace this round black fuse and unidentified coil if it got broken.
    02-20-2024, 01:07 AM
  • waterchill
    What part is this coil from a MacBook A2681 ?
    by waterchill
    Hi everyone
    I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
    So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
    IAny ideas? It is from a MacBook A2681
    Thank you...
    08-08-2024, 01:46 AM
