Samsung UN60D6000SF LED TV Sound but blue screen
  • TubeJunkie
    • Oct 2012
    • 107
    Hi. I have a Samsung UN60D6000SF LED TV. Has good Sound but blue screen. The red power light flashes when starting up. Which normally means power supply problem? Anyone have any advice or experience with this? Look how skinny the power supply caps are! Could I have a bad T-con board? I'd love to have a schematic on this model. I took some voltage readings:
    Samsung 60" LCD
    Voltage readings:
    From PS board to main board:
    1. 5.33v
    2. 5.33v
    3. 0v
    4. 17.1v
    5. 12.8v
    6. 12.8v
    7. 0v
    8. 3.28v
    9. 3.28v
    10. 3.28v
    _____________________
    Re: Samsung UN60D6000SF LED TV Sound but blue screen
    blue screen - is it only a faint dark blue or a full on, blue sort of like "no signal" screen old VCRs/TVs had?
    • TubeJunkie
      • Oct 2012
      • 107
      It's a faint blue that kinda gets lighter and darker. Much like this guys video
      http://youtu.be/s2hLKzdyDWU
        I'd say T-con or panel failure.
        • Shinju
          • Mar 2014
          • 1239
          Try disconnecting the tft ribbons connecting the t-con to to the panel, try one side power it on with a source to see if you get a picture on the side that is still connected to the t-con.
          I had a UN46 doing what yours is and it ended up being a t-con failure. But make sure your panel doesn't have moisture damage on the tft board connecting to the panel itself or you might blow another t-con if there is damage.
          • TubeJunkie
            • Oct 2012
            • 107
            Yes! I unhooked one side of the t-con board and now I have a picture on one side of the screen. So, I have a bad T-Con board. Correct?
            Also, I noticed a wet substance on the big black processor in the center of the T-Con board, after the above mentioned test. What does that moisture mean? See pic
              No, this indictes that the LCD panel is shorted on one side. Unfortunately in most cases this will not be repairable. Sorry.
              The moisture there is just left over from the thermal SIL pad... nothing to worry about.
              • TubeJunkie
                • Oct 2012
                • 107
                Awe shucks! Not the news I was hoping for. Thanks for your help guys. I really appreciate your time, and sharing of knowledge.
                  Still, it would be worth opening up the panel just to check.
                  9 times out of 10 it's not fixable but we've seen some success stories where water damage can be fixed.
                  And one case of an easy fix, with a shorted MLCC.
                  If it's scrap anyway... may as well try.
                  • TubeJunkie
                    • Oct 2012
                    • 107
                    Hmmm. I may just try it. I'venever opened a panel before. What would I be looking for? Type of Damage?
                      Signs of corrosion, usually white in nature around the tabs or components. Possible damage to the traces. If it's only components in the area affected it MAY be rescuable...
                      • TubeJunkie
                        • Oct 2012
                        • 107
                        Ok tom66, I've gotten this far. I see nothing out of the ordinary on these panel boards. Do I need to go further? Like complete disassembly of the panel?
                        • Shinju
                          • Mar 2014
                          • 1239
                          Is that all the tab bonds shown in that picture? Also, Sharp TFT board in a samsung, first time I have seen that!
                          • TubeJunkie
                            • Oct 2012
                            • 107
                            Those white tabs? They're all around each side. Is that what I need to do, take off the back of the panel? Oh, the T-con board is a Sharp
                            • Shinju
                              • Mar 2014
                              • 1239
                              No, the tabs that are glued to the green TFT board that wrap around and are attached to the LCD screen.
                              • TubeJunkie
                                • Oct 2012
                                • 107
                                Yes, that's all that I know of. What should do next?
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Retake the photo and include everyone of those tab ribbons on both left and right boards as close as you can get. I can see your photo cut off a few per side.
                                    Sharp are really good at making massive LCD panels so I guess that's why it uses a Sharp panel. Rare sight, though...
                                    • TubeJunkie
                                      • Oct 2012
                                      • 107
                                      I'm having trouble uploading pics, all of the sudden. I'll try it from another computer.
                                      • TubeJunkie
                                        • Oct 2012
                                        • 107
                                        Disregard the first pic. There are a total of 8 pics in the two zip files.
                                        tom66 ; That sounds like a good idea too. I may try that later.
                                        I also want to mention, when I previously unhooked one side of the T-con board, the one side of the screen had a normal picture. Then when I tried the other side, the picture showed up, then faded to black. Not sure if this is useful info, but thought I would mention it. Thanks
                                          09-07-2024, 05:50 AM
                                        • mar1in
                                          Samsung TU8000, backlight and sound on, stuck in blue screen
                                          by mar1in
                                          I've got this Samsung here that would be stuck in a boot loop.
                                          After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                          Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                          Thanks in advance
                                          11-08-2023, 05:43 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
