Samsung led UE22C4000 sometimes works, other times not
  • cixit
    • Jan 2015
    • Italy
    Samsung led UE22C4000 turns on only when left turned off for a variable amount of time. Mostly of the times the led makes 5 flashes and turns off. I have to wait 15-30-40 min to be able to turn on it again after turn off. But there have been a few time that it turned on immediately, other times it doesn't turn on for hours. What the hell is going on? It doesn't seem a problem related to temperature of some components.
  • cixit
    • Jan 2015
    • Italy
    Re: Samsung led UE22C4000 sometimes works, other times not
    What kind of problems can be if the tv sometimes works, other times not? Led blinks five times then turns off. What kind of components can generate such kind of intermittent fault?
    • sordids999
      • May 2013
      • 2155
      • uk
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • cixit
        • Jan 2015
        • Italy
        here it is
          09-07-2024, 05:50 AM
        • Egidio85
          Samsung UE55F8000SZ Turns on and off immediately
          by Egidio85
          good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
          This defect happens continuously, hearing the classic click of the relay every time.
          Power supply board BN44-00636B
          disconnecting the mains and lamps from the power board always causes the same problem.
          Is it normal that without anything connected this power supply turns on and off cyclically?
          any suggestions on what to check?
          thanks in advance
          03-11-2025, 12:45 PM
        • Kambi13
          Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
          by Kambi13
          Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
          Not heat related, everything is ok regarding to that.
          All voltages are present.
          Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
          Motherboard is Cedar 13269-1 F3XMC Rev A00...
          07-12-2024, 06:10 AM
          09-06-2024, 11:40 PM
