hey quick question here, got a Sylvania with a bad PSU inverter, part number is BA71G0F01042, ordered a replacement on fleabay and received number BA71G0F01043. their both listed for this model but one is for a different panel. Anyone know what the differences are? Visually identical boards with what seems like the same components and circuits.
Sylvania Ld370ss8 board compatibility
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by rustinjustMy main board is a 17MB12-2 and reads underneath that the following number 160807 LF,
Question is this board going to fit? ( see link) board is identical but from a different brand of tv but board number is same as in that it’s a 17mb12-2 board
Link to part here https://www.ebay.co.uk/itm/222990805243
This board is cheapest I can find. Also note:ordered one that was from a technica, an exact replacement, it arrived yesterday and when I fitted it it was a dead board, didn’t even show the standby light. When I piut the old board back in the tv worked but the issue... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by edugimenoHi!!
Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
At a certain point, moving stuff around, I put all wires back in place and... - Loading...
