Vizio Failing afterwarm
  • Agent24
    I see dead caps
    • Oct 2007
    • 4940
    • New Zealand
    #41
    Re: Vizio Failing afterwarm
    A comparison in voltage readings between working and not working is best, to see if anything changes between working and not working states. The idea is that if something changes you can hopefully use that to narrow down where the problem may lie.
    If it never works, and you can't compare states, then taking voltage readings anyway is still generally the first thing to do. You might notice that one voltage rail is missing, for example. Then you can try to find out why.
    To start with, you want to take readings with all boards plugged in, try to find out if there is anything obviously wrong with the readings, and then try to find out why. Unplugging boards only makes sense if the readings suggest it. Pulling boards at random doesn't usually give any sensible results. If the symptoms changes, is it because the board was faulty, or just because it's now unplugged? You need to have some idea of what unplugging something is going to do.
    If something dies after 1 minute a heat related issue is possible, a can of freezer spray would probably be used too.
    Actually in the case of it dying quickly like that, what I'd probably do is check everything in the failure state, if any rail or signal looked suspicious\missing, then check just that signal\voltage again after it cooled down and was working. Then you don't need to try to check everything during the limited time. If you found that it changes, then you should at least know where to start looking.
    That's the kind of general idea, anyway. Or at least, how I would do it to start with, I suppose. There may be better ways.
    -David VanHorn
    • Bills86e
      • Nov 2012
      • 24
      • usa
      #42
      Replaceing the Video board Fixed this problem. Now working great! .
      Searspartsdirect $168
      Thanks to you all who participated.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4940
        • New Zealand
        #43
        Good to hear!
        -David VanHorn
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • noipi
          DELL INSIPRON 14 No power blinking orange/white
          by noipi
          i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
          05-06-2025, 08:08 PM
        • jorpec
          HP Elitebook 8460p battery led white and blinking orange
          by jorpec
          Hello everyone
          I have this Elitebook that wont turn on, only the battery led is white and blinking orange, does this even without battery.
          If this is a error code i couldn't find any info about it.
          Already tested with a another charger, measure the presence on 19v on the 19v rail, checked if there was capacitors in short-circuit
          Thanks...
          05-05-2025, 04:39 AM
        • brad2157
          Vizio E70-E3 Two white vertical lines
          by brad2157
          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
          Replacement main board - Boots up fine, but starting...
          12-13-2021, 05:11 PM
        • ggil44
          Vizio M65-E0 No Picture, No Sound
          by ggil44
          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
          09-03-2024, 08:30 PM
