Vizio Failing afterwarm
  • Bills86e
    • Nov 2012
    • 24
    • usa
    VIZIO 47" HDTV XVT3D474SV had it in Bedroom with two remotes
    This is an LCD/LED Smart HDTV 03-03-2015
    Wife said "it stopped" and changed it out with the 40" LCD tv, Sony Bravia. Stored 2 months.
    I cleaned power plug, dusted, Checked batteries in remote's (bad) replaced only one set.
    In office, it powered on by remote and the JAG wheel. Nice Pic & sound.
    1st, I noticed some channals would not come on. Nice Pic & sound.
    While watching, after ten minutes it lost the picture, had black screen, had sound, then it shut off.
    White logo Blinks continually.
    Orange logo when you plug it in. When you power on the logo turns white and continually blinks.
    No picture or sound. Suspect LED driver board, CPU main mother board, power board, or T-Con (GPU) board.
    03-04-2015 in AM
    update
    This AM I unplugged the T-Con power plugs, Did a re-try. orange turned to blinking white, then in a minute this turned orange.
    unplugged, next, I plugged in Cable antenae. Then I plugged back the T-Con. Replugged in the main power cable/plug.
    I used remote and hit ON, and the TV came on with both picture & sound. This lasted about 4 minutes, then lost the picture
    to white screen, no picture. Sound is still working. This TV has some thing failing when warmed up.
    update at noon
    Now, turn power on, orange, hit remote turn ON, 100 white blinks it turned orange, hit ON and now Nothing! Its flashing orange & white
    and a minute later stayswhite, the remote will not turn that to off.
    Before I start just thowing board$,
    Anyone have suggestions?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8206
    Re: Vizio Failing afterwarm
    You got a DMM to troubleshoot with? We also need to see some high res pics.
    • Bills86e
      • Nov 2012
      • 24
      • usa
      I'd like to narrow this issue to one of the four componet boards, and just replace that.
      My guessis T-Con, as the screen went black. Any thoughts?
      I do not have electronical tool$. All I need is my #2 phillips! Refurbs or used OK
      Power supply PCU board = Vizio 0500-0305-0860
      GPU Timing control board = Vizio 3647-0062-0147 (9c)
      LED driver board = Vizio 0500-0705-0070
      Main video board = Vizio 3647-0342-0150 (4c)
      • Ltank
        • Jun 2013
        • 776
        I would check P.S. capacitors 1st. Then try Freeze mist to spray parts that are hotest.
          If you do not have at least the Volt meter, it will not be possible to see which signals or voltages are missing.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8206
            can't give you any decent advice without seeing some voltages and tests. Everything with out these would be WAG's at best.
            • Bills86e
              • Nov 2012
              • 24
              • usa
              I just figured out what is DMM. Digital Multi meter. Wags?
              Ok, I agree we start with PSU. AC in, DC out.
              My bd is AC in on bottom, two outs to LED on left top, top rt is : to vid bd, to T-Con, to Video board. So the PSU has five DC outs connectors across the top of circuit bd.
              Each of these connectors have many wires, I appreciate all the help,
              I also now understand we must eliminate each board to find the defective board.
              I had thought because I had unplug the T-con, waited, re-plug, then the TV came on, but soon failed, hadwhite screen, then after a re-start the screen was Black, that the video or the T-C was failing, not PS.
              I now have a DMM, a Fluke 8020 B multimeter. Ready to begin.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8206
                WAG = Wild Ass Guess
                Next thing we need is hi res pictures from the boards and one pic of the back of the TV with all boards in place and hooked up. Make an extra pic of the sockets of the PSU that go to the main board. Hope fully there is a pin out printed on there. Sometimes the pin out is printed on the back.
                Make some measurements with your DMM from that socket on the PSU that goes to the main board with the corresponding pin outs. GND is either a GND pin or chassis GND. That should do for the first round. :-)
                • Bills86e
                  • Nov 2012
                  • 24
                  • usa
                  I recently got a smart phone...I took the pics, now need to upload to here. (learning)
                  There are two white connectors with multiple wires/colors from PSU to the Video mainboard.
                  Two connectors to the LED driver board
                  One to the Timing control board
                  Am I looking to record voltages at each wire on the connector(s)? I can list wire color
                  and its V. of each connector. I have no schematic.
                  I have the TV rear cover off, baseplate on, standing erect with back panel faceing me. Unplugged.
                  Guessing I need to power her on to get voltages? In what voltage range should DMM be set to?
                  The connectors from left to right are: LED LED Vid-M T-Con Vid-M (top ofthe power supply board)
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8206
                    cell phone pics aren't usually great. look at them yourself before you post it.
                    Are there any pin outs printed on the PSU? Wiring color does nothing for us. If you can, have everything plugged in, turn the set on, have the black probe on chassis GND and jam the red probe of your DMM into the back of the plug. record each wire / pin.
                    • Bills86e
                      • Nov 2012
                      • 24
                      • usa
                      Here is a URL of the board, however it is laying on itsright side. 5 white are on the right
                      in this pic.
                      http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
                      OK, pwr to vid main connectors. BRB Thanks by the way!
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8206
                        ??? no url no pic?
                        • Bills86e
                          • Nov 2012
                          • 24
                          • usa
                          I powered her on, She isalive. Guessit'll be ashort while til the failure occures.
                          I'm guessing you need the voltages when its in fail?
                          • Bills86e
                            • Nov 2012
                            • 24
                            • usa
                            It posted
                            Now two minutes, I just lost picture, its now white or a light blue. I have sound.
                            I'm gonna shut off with remote, see if it does that.
                            The remote shut if off, but it will not turn the tv back on. Logo is orange.
                            Do I need it white to do the voltages?
                            • Bills86e
                              • Nov 2012
                              • 24
                              • usa
                              Unplugged, waited 5 min. Now back ALIVE.
                              YEP..........1 minute, failed, white or lt blue screen. Must mean the back-lighting is working.
                              sound is on. Will begin with Volt readings.
                              YIKES, ...........My hands are so trembling, I don't think I should do this probeing. A bit SCARRED!
                              Am I in any danger? I might accidentl touch two. maybe i have antzhymer's I'm not drinkin coffeee.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8206
                                the primary circuit is the dangerous one. To make you feel better, put the negative lead to chassis GND and only probe with one hand. If you short something out, you won't get hurt that way. The secondary you are working on is low voltage (under 30V), so not so bad...
                                But anyway... since your TV fails like that and actually does come on for a minute now, try some cooling on the main board and the t-con (can of air duster upside down).
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4976
                                  • New Zealand
                                  If you've never done it before it's normal to be a little scared. Don't worry about it. Just keep away from the primary\hot side of the PSU (where the mains cord comes in).
                                  Since the voltages we want you to check are at the other end of the PSU board, that's easy to do.
                                  Now, while the PSU you linked to is useful, it doesn't show us what *yours* looks like, and if there is anything obviously wrong with it.
                                  If you think your photos are good enough, do post them here. Check https://www.badcaps.net/forum/showthread.php?t=1868 for details on how
                                  -David VanHorn
                                  • Bills86e
                                    • Nov 2012
                                    • 24
                                    • usa
                                    4 wires PS to Vid Main
                                    orange red brown black
                                    18.7, 18.7, 0, 0
                                    8 wires PS to T-Con
                                    gray black blue green yellow orange red brown black
                                    5.08, 5.08, .05, .05, .01, .01, .01, .01, .01
                                    two rows, eight wire positions in each row PS to Video main
                                    rear row
                                    _ brown _ white purple green orange brown
                                    0, 3.3, 0, 11.8, 0, 0, 5.1, 5.1
                                    front row
                                    red black _ grey blue yellow red black
                                    .1, 3.3, 0, 11.8, 0, 0, 5.1, 5.1
                                      18.7, 18.7, 0, 0
                                      8 wires PS to T-Con
                                      rear row
                                      front row
                                      Those numbers do not mean much without knowing the connector numbers and pins names. As you can see at SJ pictures, the connector pins have names so we need more details.
                                      You need to list the connector number, pin number, name of each pin follow by the Voltage reading.
                                      For example:
                                      Connector CN201
                                      Pin 1: DIMMING SIGNAL: TV OFF = xx VDC, TV ON = xx VDC
                                      PIN 2, 3, 4, 5: GND
                                      PIN 6, 7: +12V: TV OFF = xx VDC, TV ON = xx VDC
                                      PIN 8, 9: 5.1VSB: TV OFF = xx VDC, TV ON = xx VDC
                                      • Bills86e
                                        • Nov 2012
                                        • 24
                                        • usa
                                        4 wires PS to Vid Main is CN204
                                        8 wires PS to T-Con is CN 201
                                        two rows, eight wire positions in each row PS to Video main is CN202
                                        I have no schematic, no details of what each pin is.
                                        Can we guess that the MAIN BOARD needs replaced? or are you thinking its just not getting the right power
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • noipi
                                          DELL INSIPRON 14 No power blinking orange/white
                                          by noipi
                                          i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
                                          05-06-2025, 08:08 PM
                                        • jorpec
                                          HP Elitebook 8460p battery led white and blinking orange
                                          by jorpec
                                          Hello everyone
                                          I have this Elitebook that wont turn on, only the battery led is white and blinking orange, does this even without battery.
                                          If this is a error code i couldn't find any info about it.
                                          Already tested with a another charger, measure the presence on 19v on the 19v rail, checked if there was capacitors in short-circuit
                                          Thanks...
                                          05-05-2025, 04:39 AM
                                        • brad2157
                                          Vizio E70-E3 Two white vertical lines
                                          by brad2157
                                          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                          Replacement main board - Boots up fine, but starting...
                                          12-13-2021, 05:11 PM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
