LG: DT-42PY10x "issue with colours"
+ More Options
Posts
  • Alex-g
    • Mar 2015
    • 5
    I picked up this plasma off the side of the road (why not)
    And it worked OK! Bright colours and no burn in.
    It started out with sparklies on certain colours, or strangely only in the background (hooked up a Game console) but they went away after a few mins of warm up, and ran for a few hours for a proper check.
    Later when i went to watch a movie i noticed its come back, and worse now with whole colours being strange.
    Attached pics of issue
    Funny colours
    http://s17.postimg.org/ay6yvfqjz/IMG...113524_003.jpg
    Back of set
    http://postimg.org/image/r3wc4nrwl/
    Ive gone through the "plasma troubleshooting" sticky, hence the sparklies part. But to little avail.
    Ive checked most voltages i can find and tweaked them, all correct but no difference.
    There are stacks of adjustments though, (-Vy), (Vscan), ect. Which i can find both the pots and test points for (usually across a resistor or something) But no info on correct voltages.
    The set is now OK on switch on, then after 30 secs colour definition degrades, almost the opposite issue. Makes me think an issue with things changing as it warms.
    Any pointers?
    EDIT:
    After turning off and re-seating all the little Y ribbons on the left hand side, it now looks like this
    http://postimg.org/image/kjka1hwbb/
    And after it has run for a bit the screen goes purpley.
    Cheers,
    Alex
  • Alex-g
    • Mar 2015
    • 5
    Re: LG: DT-42PY10x "issue with colours"
    I've now found if I twist the set sparklies/purple may disappear or appear, so thinking a connector or solder joint (god I hope not)
    I've got the main board off and I'm down to the individual connectors cleaning and touching up with CRC contact spray. Found another 3 adjustments pots too.
    All fuses and voltages are Ok as far as I can tell. (Va, Vs, 5v, 12v)
    Any pointers at all? This is the first plasma I've opened up and aside from the guides I've read I'm pretty well flying blind.
    • lp20th
      Samsung Plasma TV Power Supply Issue
      by lp20th
      I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
      11-28-2023, 10:28 AM
    • celiabrown
      Issue with Plasma Philips 37inch chassis FTL2.1
      by celiabrown
      Hello guys,
      My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
      Can someone has any symptom like this ?
      Thanks​
      05-09-2024, 10:56 PM
    • piernov
      NVidia bumpgate
      by piernov
      Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
      Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
      May complete this post at a later date with more details.
      Basically issue is a combination of thermal dissipation of the chip with hotspot,...
      03-27-2021, 10:34 AM
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
