Sony KDL-32EX400 fault finding
    Re: Sony KDL-32EX400 fault finding
    Originally posted by t4796
    ok here's some before and after! almost everything, i was too tired to complete tonight. i've copied the old values into this post.
    BEFORE WITH BAD IC6301
    ------ STBY | POWER ON
    C6325 340V 340V
    C6117 7.75V 13.45V
    C6118 8.05V 13.89V
    Vcc @ CXA3809m 7.77V (stby) 13.48V (on)
    Pin2 (mode)@ CXA3809m** 0.3mV (stby) -24.3mV (on)
    pin3 (AC_detin) @ CXA3809m** 0.601V (stby) 0.576 (drops)
    T-Con VCC, REG 12V, UNREG 12V, all 0v or close enough stby or on.
    AFTER IC6301 SONY A3809 REPLACED
    C6325 339V 394V
    C6117 12.45V 14.02V
    C6118 12.41V 14.34V
    Vcc @ CXA3809m 12.44V (stby) 14.04V (on)
    Pin2 (mode)@ CXA3809m** 12.38V (stby) 93.8mV (on)
    pin3 (AC_detin) @ CXA3809m** 5.36V (meter on DC) 1.83V (meter on AC)
    Secondary voltages to follow when i've had a sleep
    Thanks!
    • t4796
      • Feb 2015
      • 79
      As per my posting, standby voltage was clearly a lot higher with the working ic, acdetin was up to 6v from 0.6v, and as predicted by you budm the mode voltage was at vcc in standby mode with a working IC
      Here's the document I found with a repair process. It mentions adding the two diodes. I notice on the hires screenshots of the power supply board ending in -12 on shopjimmy (mine ends with -11) these diodes are present!
      Here's the spanish doc as promised. If I take any more measurements they'll be when I reopen the tv to fit the two additional diodes.
      Would anyone be able to theorise the reason they have been added?
      cheers!
      • PowerAmpFreak
        • 982
        • Sweden
        I would expect those two diodes will act as clamping devices, making the chip more robust to handle transients.
          cheers!
          Does it says which pin of the IC or where the two diodes are connected too?
          BTW, thanks for the info.
          • sickboy
            Strange CRT Fault (Sony Trinitron M1410U)
            by sickboy
            This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
            11-10-2024, 05:02 AM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:27 AM
          • sarry86
            sony dav-dz650 home theatre psu that has fault
            by sarry86
            Guys I am in need of your help, I forgot to discharge capacitors and went directly to check for the bad transistor, unfortunately I shorted this pwm ic, I'am not very good at troubleshooting hardware issues, can you guys help me know the similar ic to the ssc6200? It is a sony dav-dz650 home theatre psu that has fault, please help me...
            12-11-2021, 11:19 AM
