STB3.3v = 0.4V on Panasonic p42v10
  • rvanpruissen
    • Mar 2013
    • 12
    • The Netherlands
    Hi guys,
    Recently I've been given a faulty Panasonic p42v10. The symptoms are as follows:
    • No response when on power
    • No standby LED
    • No relay clicks
    After some research, I found out that:
    • STB5V rail is measuring 4.5V (just within tolerance?)
    • STB3.3V rail measures 0.4V.
    • STB3.3V has a resistance to ground of 4.2ohm with no cables connected to the board (A-board).
    At this point I'm not sure how to proceed as there are many components connected to the STB3.3V rail, all of which could be shorting to ground.
    Any help is appreciated!
    Cheers, Rick
  • Agent24
    I see dead caps
    • Oct 2007
    • 4954
    • New Zealand
    Re: STB3.3v = 0.4V on Panasonic p42v10
    Where does STB3.3v come from? PSU directly or derived from a secondary regulator on another board?
    Can you put up some photos?
    -David VanHorn
    • rvanpruissen
      • Mar 2013
      • 12
      • The Netherlands
      There's a regulator on the A-board (IC5480) which supplies the STB3.3V, based on the STB5V. I've included some pictures:
      • 409: Overview
      • 408: A-board component side
      • 412: Close-up of IC5480
      • 413: A-board foil side
      • 414: Close-up of IC1100 which is should be powered by STB3.3V (among others
      Meanwhile, I've found out that when I disconnect A3 connector (to D-board) and leave the rest plugged in, the TV powers up: relays click, backlight is on but still no standby light. At this point, STB3.3V becomes 0,67V (less load I suppose).
      • Neelix
        • Oct 2013
        • 145
        • South Africa
        Service manual -
        • Neelix
          • Oct 2013
          • 145
          • South Africa
          You're measuring 4.2 ohm between STB3.3V and GND which is far too low. One or more parts on the STB3.3V supply line is shorted and pulling the STB3.3V down. That's why you're only measuring 0.4V. You must find out which part. Start by removing L5480 from the A board and then measure the resistance between STB3.3V and GND again
          • Neelix
            • Oct 2013
            • 145
            • South Africa
            The parts on the A board can be tiny and easy to loose. So be careful
            • TVRepairNoobie
              • Feb 2015
              • 158
              Hi rvanpruissen,
              Test D503 on the P board to see if its open or closed. It is shaded green at the lower center.
              • TVRepairNoobie
                • Feb 2015
                • 158
                When A-Board is not connected, you will not be able to power on the TV. At least this is my case with TC-P42S1 model. (no LED indication at all).
                • rvanpruissen
                  • Mar 2013
                  • 12
                  • The Netherlands
                  Thanks guys! I'm baffled to see that D503 measures open both ways, using the diode tester on my multimeter. Could this be the source of the problems? Or am I doing something wrong (sorry, sometimes I'm missing some basic electronics skills )
                  To fix the A-board, I think I'll go with Neelix' plan to remove L5480 first and test whether IC5480 itself is shorted to ground, or the short is somewhere in the rail. Not sure about when though, bit busy now.
                  Keep em coming please!
                  • rvanpruissen
                    • Mar 2013
                    • 12
                    • The Netherlands
                    Crap. Just took a look at the schematic and D503 is parallel to a transformer, so thats what I'm measuring. Any particular reason to believe it's D503 TVRepairNoobie? Otherwise I won't try to get it out of the board. Thanks again!
                    • TVRepairNoobie
                      • Feb 2015
                      • 158
                      rvanpruissen, I am a newbie (4 x TV fixed) working on a similar TV (TC-P42S1). The D503 is shorted when in circuit mine measures exactly the same. But I don't think it should be open thus, I suspect D503 might be faulty.
                      Hopefully, the experts here can shine some light in this matter.
                      If the diode on D503 is bad, I cannot find replacement for it anywhere. Diode has the follow label: T3D 97 or T 3D 97
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        If the diode tests open both ways its shorted, desolder and test it out of circuit.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          There should be more numbers like 50n60 or something similar.
                          • Neelix
                            • Oct 2013
                            • 145
                            • South Africa
                            For D503, have a look at this thread - https://www.badcaps.net/forum/showthread.php?t=17969
                              The Diode is the back to back snubber diode network to clamp down the back EMF, you cannot use Ohm mode or Diode mode to test it, you have to supply enough voltage to reach the breakdown Voltage.
                              https://cdn.badcaps-static.com/pdfs/...386e62dcd7.pdf
                              page 4
                              • rvanpruissen
                                • Mar 2013
                                • 12
                                • The Netherlands
                                Thanks budm. A bit out of my league though I have no reason to think this diode is bad, so I'll focus on the STB3.3v line first.
                                • rvanpruissen
                                  • Mar 2013
                                  • 12
                                  • The Netherlands
                                  Ok guys. So after removing L1100 I've isolated the problem to the STB3.3V supply to IC1100, see attached image. The caps indicated in yellow are the ones I've removed so far and still there's only 4.2ohm resistance between this part of the STB3.3V line and ground.
                                  Any brilliant ideas for the next step or should I assume IC1100 is shorted? I'm thinking maybe the crystal's capacitors on the right, or even further down the lines coming from IC1100.
                                  Please help this electronics noob on his epic journey
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4954
                                    • New Zealand
                                    If there is nothing else connected to the STB3.3V rail, you have removed all the capacitors, then logically it would point to IC1100 being bad. But you must be sure there is nothing else you have missed, because it doesn't look like that IC will be easy to get if it is bad.
                                    -David VanHorn
                                    • rvanpruissen
                                      • Mar 2013
                                      • 12
                                      • The Netherlands
                                      Could the short also be on one of the 100 connection of IC1100 I didn't 'disconnect'? Or is it unlikely there's an internal connection between the 4 IVDD STB3.3V connections and the rest of the connections.
                                      Any suggestions on where to check next? IC1100 is indeed difficult (impossible?) to find (and replace).
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4954
                                        • New Zealand
                                        I don't think there is anywhere else to check. If the problem is between L1100 and IC1100 and you have disconnected the capacitors it is very likely IC1100 showing that 4.2 Ohms.
                                        It seems it's just a microcontroller, so as far as I can tell there should be no low resistance paths between its power pins and anything else, it's not like it's doing any heavy current switching or anything.
                                        It seems odd that a microcontroller would go shorted, so it's also possible the PCB itself has the short (can happen if there's been physical damage), or there's a solder ball under the IC or such.
                                        If you have the tools (hot air etc) and can remove that IC, check for solder balls\bridges\whiskers. See if that 4.2 Ohms is still on the IC out of circuit. See if it's still on the board with the IC removed.
                                        If the IC seems OK out of circuit and there is no 4.2 Ohm short on the board, it may have been a solder bridge. Resolder the IC and see if it is fixed.
                                        Otherwise, try to find a new IC or replace the whole board I guess... unless someone else has any other clever ideas.
                                        -David VanHorn
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • jaroslav.psenicka
                                          Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                                          by jaroslav.psenicka
                                          I have a Lenovo Yoga 13 Panasonic here, when powered
                                          • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                                          • most voltage rails seem OK (see image below, red labels)
                                          • resistnace to ground mostly seem OK as well (blue labels)
                                          the only suspicious is the 0.0V rail (2nd from left, top row)
                                          • the resistance to ground is rather low (1.9ohm)
                                          • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                                          also tried new BIOS, no change
                                          I can't find a schematics for the board - can some of you gurus look at the voltages?...
                                          05-02-2024, 05:59 AM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • lefetylorant
                                          Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                                          by lefetylorant
                                          Hello Everyone,
                                          Long story short, I got this unit for very cheap.
                                          I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                                          I've performed some measurements:
                                          - 20V rail perfectly...
                                          09-14-2023, 05:05 AM
                                        • bimole
                                          Weird behavior on 3.3V rail of a CORSAIR CX600
                                          by bimole
                                          A colleague gave me an apparently ill CORSAIR CX600.
                                          He told me that he heard a banging noise, and smelt the magic smoke.
                                          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                                          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                                          It's another story on the 3.3V rail...
                                          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                                          02-13-2025, 04:49 AM
