STB3.3v = 0.4V on Panasonic p42v10
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: STB3.3v = 0.4V on Panasonic p42v10
    I guess you went as far as you can go, unless you have a very sensitive Ohm meter or a Leakseeker 89. You could cut the little traces of interest and find out that way if the short disappears. However since it seems the IVDD pins are shorted to GND, this is a lost cause and either the chip or the board needs to be replaced.
    • rvanpruissen
      • Mar 2013
      • 12
      • The Netherlands
      Thanks guys. I might try removing the IC in the weekend. I guess the worst that could happen is that I gain some experience in removing IC's
      • Agent24
        I see dead caps
        • Oct 2007
        • 5037
        • New Zealand
        There are some good video tutorials on the internet. Hot air is the easiest way if you have the tools and don't want to destroy the IC. Chipquick is also quite good.
        Without either you can cut the leads off with a knife, clean the pads with iron and wick, but then the IC is done. That method is only good when the IC is known bad and you are replacing it.
        -David VanHorn
        • rvanpruissen
          • Mar 2013
          • 12
          • The Netherlands
          Hey guys, in the meantime I've bought a new signal board. Unfortunately it still doesn't work, but some things have changed. Now when I turn on the TV I hear the relays clicking and the backlight turns on. However, theres nothing on the screen (no OSD), I have 13 blinks and the TV shuts itself down.
          I've had some time to cool down and gather some courage to start over again. Any ideas where to start? Cheers. Rick.
          • tw2005
            • Oct 2011
            • 6458
            13 blinks sounds like another bad A board. New board or recycled/ might be better to send back
            So the panel fires up? it's plasma so no backlight.
            • rvanpruissen
              • Mar 2013
              • 12
              • The Netherlands
              #26
              "Fires up" indeed, sorry habit from laptop repairs This was indeed a recycled board from a seller who claims it's working. Maybe it isn't...
              • Nagy Daniel
                Lowest possible resistance on laptop motherboard rail - Guide Table request
                by Nagy Daniel
                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                So, I generated a table with AI so I can...
                03-04-2025, 08:24 AM
              • jaroslav.psenicka
                Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                by jaroslav.psenicka
                I have a Lenovo Yoga 13 Panasonic here, when powered
                • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                • most voltage rails seem OK (see image below, red labels)
                • resistnace to ground mostly seem OK as well (blue labels)
                the only suspicious is the 0.0V rail (2nd from left, top row)
                • the resistance to ground is rather low (1.9ohm)
                • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                also tried new BIOS, no change
                I can't find a schematics for the board - can some of you gurus look at the voltages?...
                05-02-2024, 05:59 AM
              • Victor Moreira Silva
                Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                by Victor Moreira Silva
                I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                Well, my decice specs are the following:
                Model: Acer Nitro 5 AN517-54-55T5
                CPU: Intel Core i5-11400H
                GPU: NVIDIA GeForce GTX 1650
                Motherboard: GH51G LA-L181P Rev:1c
                The symptom:
                When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                05-26-2025, 10:49 AM
              • lefetylorant
                Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                by lefetylorant
                Hello Everyone,
                Long story short, I got this unit for very cheap.
                I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                I've performed some measurements:
                - 20V rail perfectly...
                09-14-2023, 05:05 AM
              • bimole
                Weird behavior on 3.3V rail of a CORSAIR CX600
                by bimole
                A colleague gave me an apparently ill CORSAIR CX600.
                He told me that he heard a banging noise, and smelt the magic smoke.
                After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                It's another story on the 3.3V rail...
                I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                02-13-2025, 04:49 AM
