Philips 20PFS121/01
  • DrDaveR
    DrDaveR
    • Jan 2015
    • 9
    Philips 20PFS121/01
    Flashes on from standby then no screen/ or sound. then reverts to standby.
    seems as though inverter not stabilising. can any one supply circuit or say which caps are on 14.5v rail?
  • DrDaveR
    DrDaveR
    • Jan 2015
    • 9
    Re: Philips 20PFS121/01
    Power supply is DAC-12M019 ADF 3139-128-77612
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • Bad_IC
      Philips TV 37pfl5604h/12 no standby voltage
      by Bad_IC
      I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
      These are the voltages in some pins of IC fsq510:
      Vcc=18v
      D=320v
      Vstr=154v
      Unfortunately, I couldn't find the schematic
      What else could I check?
      Is it possible to provide standby voltage from an external source to allow the TV to turn on?
      Thank you​...
      11-08-2024, 01:07 PM
    • jasonbay13
      Philips 37HFL5682L/F7 no standby light, incomplete service manual?
      by jasonbay13
      picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
      am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
      12-01-2023, 09:55 PM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • Raulnn
      Philips 43pft4112/12 blinking standby
      by Raulnn
      good evening. I have this basic tv, with an all-in-one board. This tv has a common fault in the primary power area. the tv did not turn on. I bought a repair kit. I have installed all the parts of the kit, but now the tv turns on the standby light intermittently but does not start. the flashing is very fast. What can be? Does anyone know the model? Thank you
      01-08-2023, 04:13 PM
