Samsung growing small black line on screen
  • jjzepplin
    • Aug 2014
    • 52
    Hey there. I have a 2006 Samsung that I've owned since new. The caps went bad so I fixed that about 2 years ago. Now I am seeing a small black line on the screen that appears to be getting longer. I know this thing is old but I can't afford a new one right now. Any ideas?
    Model- LN-s4051d
    Re: Samsung growing small black line on screen
    It sounds like a bad LCD panel... but care to share a picture of the fault?
    • jjzepplin
      • Aug 2014
      • 52
      So I moved and finally pulled this thing out and here is the problem.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Lol a year later Also the foils in the Lcd are breaking down try applying pressure in that area.
        • jjzepplin
          • Aug 2014
          • 52
          Yeah I know. I bought a new house-renovated the old one for renting-Got a promotion at work-more hours of course-almost completely paid off all my debt-built a new kitchen in the new to me house and bang. Here I am again back to tinkering with this tv.
          So I tried the pressure thing.
          Not much happens but I can see color changing around the pressure point.
          Line does not go away.
          • ozzy214
            • Nov 2013
            • 319
            • usa
            Bad panel
            • jjzepplin
              • Aug 2014
              • 52
              So it has just plain worn out?
              • ozzy214
                • Nov 2013
                • 319
                • usa
                Pretty much....take a pic and part it on ebay proving boards good but panel fubar!
                • jjzepplin
                  • Aug 2014
                  • 52
                  Maybe i will just keep it til it gets worse. I only use it in my bedroom and it puts me to sleep. Most of the time I don't notice it. I wouldn't get much for it anyway I suppose.
                  • Kiberge
                    Samsung LH82QENELGC/EN Help needed - Static line on screen
                    by Kiberge
                    HI guys!
                    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                    04-22-2024, 11:28 AM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
                  • KYBOSH
                    Trying to Save - Samsung UN55JS6500 - A line down the screen + Falling LED diffusers
                    by KYBOSH
                    Picked this one up today.
                    In addition to falling LED diffusers there is a single line here that maybe a deal breaker.
                    From my reading on these boards it is said that the issue is likely a sign of failed tab drivers, ribbons or tab bonding to the panel.
                    Wanted to get a 2nd opinion from you guys before I gave up the ghost.
                    Great looking TV otherwise.
                    Is there any tricks I can do to try to save this one?
                    If so, i'll gladly order a set of backlights and save this one from the landfill..
                    Thanks in advance
                    10-04-2024, 11:00 PM
                  • JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                    by JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                    Please help. Thanks in advance!
                    08-12-2025, 11:45 AM
