Panasonic TCP42S30 SN Board reflow-Help out a noob!
    Re: Panasonic TCP42S30 SN Board reflow-Help out a noob!
    One thing I did when I repaired my U30B (this model is identical except it has smart features) was install a light bulb in series with the SN board power connector. Alastair suggested this and I do recommend it for first power ups of repaired boards. The idea with this is, if the worst happens and there's a short on the board, the bulb will limit the current - acting as a resistor - and give you a handy indication by lighting up. This SHOULD limit any damage, perhaps it will even save the responsible part, if it's just a soldering fault or such!
    Of course, having the bulb in does cause the Vsus at the SN board to drop, and so can affect the picture, but as long as nothing goes pop, you should be good to remove it completely.
    I used a 150W bulb, which was enough for most ordinary TV to not affect the picture, the bulb intensity would vary with the picture. A 60W bulb was too low to start the TV most of the time. If full white or very bright scenes came up, it would trip SOS 6 (and the picture would look awful.) But, otherwise the TV worked fine with a bulb.
    This is using a 230V AC lightbulb on a 200V DC circuit (note that 200VDC = 200VAC for a bulb, due to RMS...)
    • WHaThEFLuX
      • Feb 2015
      • 277
      I just might try that......with everything on the board I powered it up and it behaved as if Q441 and D481 were still lifted, grey flash and ERC 6 blinks.....does that mean I soldered IC502/Q531 incorrectly?
      "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
      -retiredcaps
      • WHaThEFLuX
        • Feb 2015
        • 277
        -retiredcaps
          Yes possibly. That is what mine did when those parts were not properly in.
          • WHaThEFLuX
            • Feb 2015
            • 277
            Everything looks ok, could solder be shorting two pins of the IC since they're so close together?
            -retiredcaps
              Have you checked under a loupe/magnifier to see if the pins are properly reflowed?
              Also, are the parts on the right way?
              • WHaThEFLuX
                • Feb 2015
                • 277
                they're in the right way, the solder looks sloppy but there's space in between the pins, idk, maybe I'll lift it and try again.....
                -retiredcaps
                • WHaThEFLuX
                  • Feb 2015
                  • 277
                  Not sure how exactly, but I finally have a working set!
                  After contemplating taking a sledge hammer to the panel and really "fixing" it for good, I decided to go over everything one more time.
                  Finding absolutely nothing wrong is certainly discouraging, so I started thinking of abstract things to try. I lifted the new IC502 off the board and replaced it with the original one, so I had new DG302s, a new Q531, and the old IC502.
                  The old Q531 must have been bad and the new IC502 must have been a dud because when I powered it up low and behold I got the no signal box on the screen!
                  The ERC caps on the SC board buzz pretty loudly, about twice as loud as the ones on the SS board, but I'm not complaining, the picture quality is great and better than I expected.
                  I'd like to thank tom66 and tw2005 for their help, advice, and input, without them I would've never gotten anywhere with this set......you guys are awesome!!!
                  -retiredcaps
                  • tw2005
                    • Oct 2011
                    • 6457
                    Did you a flux pen at all/ One thing I found makes a world of difference to neatness and how the solder flows was adding flux.
                    top effort for a noob! Are all the screws in and tight? i would not have expected it to be buzzing too loud
                      Nice fix. My set hardly buzzed at all so I'd be careful to check screws as tw suggests...
                      • WHaThEFLuX
                        • Feb 2015
                        • 277
                        I did use flux towards the end, it made everything flow really well. The board contact points on IC502 were really messy once I lifted it, so I used the flux and a fine tip on the iron to even them out, even though they were so small it was surprisingly easy. I must say the flux is very sticky, I'd end up shifting it out of place because it kept sticking to my tweezers! The screws are in as tight as I'm comfortable making them, if I put my ear next to the board it's the ERC caps themselves that are humming, wondering if something got slightly damaged when I popped the ERC cct, who knows.
                        Anyways, here she is in all her glory!
                        -retiredcaps
                        • tw2005
                          • Oct 2011
                          • 6457
                          [ATTACH]107474[/ATTACH]
                          LOL, I was wondering where my flux pen line went . Into the quote.
                          Now , when you describe buzzing caps as pretty loud and then come back and say "if I put my ear next to the board" it's not quite the same description.
                          Sounds normal if you have to get your ears close to the board to hear a buzz.
                          • WHaThEFLuX
                            • Feb 2015
                            • 277
                            I only put my ear up to it to locate exactly where it was coming from.......As a reference, I have to put the volume up to about 60 to hear the audio clearly over the buzzing. If there was a scene with no music and just dialogue, you would easily be distracted by it. I'll be connecting it to a system so it's really no big deal, I just wanted to be sure that something wasn't actually wrong.
                            -retiredcaps
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                              by sam_sam_sam
                              After all of...
                              07-13-2024, 08:14 PM
                            • canadaboy25
                              Panasonic TC-P54VT25 No image. A or D board?
                              by canadaboy25
                              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                              The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                              01-17-2021, 01:06 AM
                            • stecos
                              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                              by stecos
                              Hi everyone!
                              For my passion for technology I'm now collecting several...
                              11-28-2022, 11:39 AM
