Panasonic TCP42S30 SN Board reflow-Help out a noob!
  • WHaThEFLuX
    • Feb 2015
    • 277
    Re: Panasonic TCP42S30 SN Board reflow-Help out a noob!
    Just tried to power on with the room pitch black, absolutely no detectable light coming from the panel at any point.
    I also tried checking for continuity at SS61 and SS33 as instructed by the flowchart, they both checked out ok.
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
    • tw2005
      • Oct 2011
      • 6458
      not sure what to make of it unless the panel has a small fracture and somehow not shorting the boards. photos
      • WHaThEFLuX
        • Feb 2015
        • 277
        Idk how you'd ever be able to tell from the photos, but the small chip in the center of the light is the only visible blemish on the panel.
        -retiredcaps
        • WHaThEFLuX
          • Feb 2015
          • 277
          I read a few threads where members have made it to this point, but it was never clear as to how they remedied their sets, I know a few of them just threw replacement boards in until it was fixed......could it be the A board? I checked IC5000 and all the voltages are there, I'm really stumped with this one.
          -retiredcaps
          • tw2005
            • Oct 2011
            • 6458
            you're right, i can't . more interested in the rear but a chipped panel maybe the issue. as far as i know there is no protective filter glass on these so it's conceivable there's a fracture and gas has leaked.
            more opinions would help. do you have a jewellers loupe to have a real good look at that chip, maybe a pinhole there?
            • WHaThEFLuX
              • Feb 2015
              • 277
              Funny you mention that, I just got one in a resistor kit.....the chip appears to be superficial but I'll see what I can do.
              I'd love to get some more opinions, you're the only one who seems to have any interest, I wouldn't even be this far if it wasn't for you!
              If there's anything else you like to see on the back just let me know, maybe there's a voltage diagnostic I missed.
              -retiredcaps
              • tw2005
                • Oct 2011
                • 6458
                with photos you can go advanced and the upload using manage attachments
                • WHaThEFLuX
                  • Feb 2015
                  • 277
                  -retiredcaps
                  • tw2005
                    • Oct 2011
                    • 6458
                    i'm a pessimist. I'm sure everyone's interested, i can't offer much more but i await the rear shots of the internals and cabling
                    • WHaThEFLuX
                      • Feb 2015
                      • 277
                      Internals and cabling? Can you be a little more specific, as in the panel ribbons or power connections?
                      -retiredcaps
                      • tw2005
                        • Oct 2011
                        • 6458
                        I want to see the rear with all the boards exposed, cabling etc. Everything would be nice
                        • WHaThEFLuX
                          • Feb 2015
                          • 277
                          Ok I'll give it a shot, anything in particular?
                          -retiredcaps
                          • WHaThEFLuX
                            • Feb 2015
                            • 277
                            By exposed do you mean both sides of the board or just as detailed as possible?
                            Or do you mean the rest of the SS board and the lower C board?
                            -retiredcaps
                            • tw2005
                              • Oct 2011
                              • 6458
                              I'm just looking to see if it's all connected right or something silly. If I knew what it was I'd tell you. I have no idea because if the light is on the font as per normal, the SN onboard LED is on green and I assume if you get close to the Sn and SS boards they both have a faint buzz then that leaves me thinking a-board or panel.
                              • WHaThEFLuX
                                • Feb 2015
                                • 277
                                They definitely both have the faint buzz, I've gone over all connections very carefully, the only boards I can't really get a good look at are the C board and the K board.......Is there anyway to troubleshoot the A board besides testing for voltage?
                                If everything was operating normally, wouldn't the power LED turn green? I apologize for all the questions, I'm just not one to give up until I've exhausted all options, and you're the most knowledgeable person on the subject, I'm just trying to cling to the possibility that it's not the panel.
                                -retiredcaps
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  No, in the US the LED is only Red, ours goes green when active and red in standby and red blinking with shutdown on error.
                                  don't know of any way except if you had a remote and had full control, maybe hook an antenna up and see if it has channels stored and sound, there a video out you could hook up to an external monitor or another TV to see if there any activity, will not show pop up menus though from that .
                                  maybe keep an eye out for another broken 42S30 with a good screen.
                                  I'll leave it at that , for someone to come up with some ideas. Sounds like you repaired the SN ok, bit of a bummer though.
                                    @flux, would you be able to borrow a scope/CRO for a quick test of SN/SS board output?
                                    • WHaThEFLuX
                                      • Feb 2015
                                      • 277
                                      Ahh, the great tom66, welcome. You had some really good input in other Panasonic Plasma threads, thanks for joining. Where would one acquire such a device?
                                      -retiredcaps
                                      • WHaThEFLuX
                                        • Feb 2015
                                        • 277
                                        tw, I'll try to source a remote and see if I can get into service mode, you said any newer panasonic remote will do the trick? Also, you think I should try to hook up some kind of video out and see if anything happens? Wouldn't there be a Viera "splash screen" that displays even with nothing attached?
                                        -retiredcaps
                                          Maybe you have a friend or workplace that will let you borrow it? You can buy used ones on eBay from ~$50 upwards.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
