Samsung PN51D490A1D stuck pixel row help
  • NoDoz
    • Feb 2015
    I'm having a "stuck pixel" issue on an out-of-warranty Samsung PN51D490A1D. It appears as though two pixel-wide vertical rows (separated by one working vertical row) are "stuck" or missing a color field. The issue presented itself one day and did not get better or worse for months. I ended up picking up another TV around the holidays but would like to attempt to fix this if it were a feasible thing to do.
    I tried disconnecting every ribbon cable and cleaning them with isopropyl alcohol (a few times) with no luck. I'm mostly just wondering if this is for sure a panel issue, or if a certain board tends to fail. It seems like board failures present symptoms far worse than this, but electronics repair isn't exactly my specialty so I only know what I've read thus far (which has been far more people with issues than solutions.)
    Any thoughts? I read this thread about running the diagnostics, and have to dig a jumper out of my box of spare computer parts, but I thought that starting a thread in the meantime would be helpful in case it's an "obvious" panel issue.
    Pics from another forum from a user with the same issue are posted below.
  • NoDoz
    • Feb 2015
    Re: Samsung PN51D490A1D stuck pixel row help
    As an additional note, I ran through the diagnostic tests in this thread. It ran through the color slides and really didn't show me much, but I guess if a board was bad it may have been more obvious. I assume it to be a cable or the panel itself at this point, but I don't know where to start with cable diagnostics.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      COF Chip, Tab or Panel--Unrepairable sadly.
      TELEFIX
      • Kjell
        Samsung Series 9 - BIOS issue
        by Kjell
        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
        08-01-2025, 09:15 AM
        09-07-2024, 05:50 AM
      • vincentedel
        Samsung SyncMaster 740n Phase Control Issue
        by vincentedel
        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
        04-22-2025, 12:33 AM
      • Manucsl
        QE65Q800TATXXC Samsung TV Issue
        by Manucsl
        Hello.
        My TV is a QE65Q800TATXXC Samsung TV.
        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
        Any ideas to check would be very appreciated 😊
        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
        02-19-2025, 07:47 AM
      • rumi409
        LG OLED C1 Pixel Cleaning Made Picture Worse
        by rumi409
        ​​​​​​ Hi,
        I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
        11-15-2024, 01:09 AM
