Panasonic TC-P50C2 dead
  • rdagijones
    • Jul 2010
    • 5
    I have a Panasonic TC-P50C2 with no power up and no lights of any kind. I found on this forum a similar situation (https://www.badcaps.net/forum/showthread.php?t=40922). When I received the TV it had a blown fuse so I replaced the fuse. No change. I then replaced the power board and still no change ... no power ... no lights. It could be the signal board but I don't want to keep throwing money on this TV without a little more testing. How can I make sure that whatever blew the fuse did not take out many boards with it?
    Here is what I have done lately:
    • Tested the "STBY5V" pin on Power Board connector that goes to Signal Board. Tests 5V.
    • Removed the Signal Board and closely inspected it with a magnifying glass looking for defects. (I know there can be problems I cannot see, but I have spotted a burned chip in the past that saved me lots of time.)
    What would someone suggest next?
    What pictures or additional information can help you help me?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50C2 dead
    generally if you have 5v stdby and no LED the A-board is toast. All I could suggest is to download the manual and follow the stdby 5v path.
    pg34, 5v stdby goes to ic4700 at pin 7, that generates stb 3.3 pin8 & stb 1.2v pin 6 .
    • rdagijones
      • Jul 2010
      • 5
      Ordered the A-Board. I will keep you posted on how the repair goes. Thanks for the insight.
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • k370
        Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
        by k370
        I have a NM-A321 board that is dead, with no power at all.
        When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
        With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
        • +3VALW
        • +5VAUX
        • 1.2VSUS_PWRGD
        • 3VALW_PGD
        • 1.05VAUX_PWRGD
        Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
        The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
        09-23-2024, 11:57 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
