another 42jp350 plasma turns on but....
  • bullpeters
    • Feb 2015
    • 4
    • australia
    My LG 42JP350 plasma, turns on but no sound or picture. the power supply is OK, it outputs the correct voltage. the ZSUS and XSUS heatsinks warm up, some warmer than others, but they are all warm. I assume they are ok because the power supply powers up and stays on. the power led responds to the remote commands, there is just no sound or picture. There is no brightness at all on the screen.
    Is the plasma screen gone?
    your thoughts welcomed
    Mick
  • sordids999
    • May 2013
    • 2161
    Re: another 42jp350 plasma turns on but....
    Vs/Va voltages ok ?
    • tw2005
      • Oct 2011
      • 6458
      did you mean ysus and zsus heatsinks warm? might be worth isolating the main av board and jumper the test pattern generator on the logic ctrl board
      • bullpeters
        • Feb 2015
        • 4
        • australia
        More information please.
        test pattern generator?
        Yes xsus etc heatsinks
        more information about testing please
          Can you supply some pictures of the parts in your TV...
          • tw2005
            • Oct 2011
            • 6458
            • bullpeters
              • Feb 2015
              • 4
              • australia
              TW2005 Awesome, just what i need. i will hook up the scope and have a look this afternoon. you have ll been very helpful, will let you know how it goes
              • Stephen
                MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                by Stephen
                MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                03-15-2024, 09:37 AM
              • www
                LG L192WS-BN backlight turns off after 1 second
                by www
                I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                03-24-2024, 05:26 PM
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • Ollerenshaw
                Samsung plasma tv PN51F5300BF - jerky staticky picture on whole screen until warm up
                by Ollerenshaw
                About 50% of time, on switching tv on, there is a jerky staticky picture over whole screen. After some seconds (variable, 5 to 20 seconds) picture suddenly becomes normal.
                Nothing appears abnormal inside.
                I'm not a service technician. Main questions: Any ideas as to problem? Worth taking to repair technician? My skills would allow replacing a board but nothing more complicated.
                Photos and video attached.
                Thanks for any ideas....
                11-01-2022, 11:55 AM
              • Egidio85
                Samsung UE55F8000SZ Turns on and off immediately
                by Egidio85
                good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                This defect happens continuously, hearing the classic click of the relay every time.
                Power supply board BN44-00636B
                disconnecting the mains and lamps from the power board always causes the same problem.
                Is it normal that without anything connected this power supply turns on and off cyclically?
                any suggestions on what to check?
                thanks in advance
                03-11-2025, 12:45 PM
