Samsung PS42C450B1W Plasma Horizontal lines
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi, I have here a Samsung 42 inch Plasma TV, It powers on fine but has a few horizontal lines going across the screen, Can this be fixed or is it a bad pannel?
    Here's a pic of the fault,
    https://lh6.googleusercontent.com/-O...217_142243.jpg
    Re: Samsung PS42C450B1W Plasma Horizontal lines
    Possibly a panel failure, worth checking Y-buffer connections are properly seated.
    • Easky15
      • Sep 2013
      • 285
      • Ireland
      Thanks tom, Just tried that and still the same, Time for the bin.. ;-)
        Well, the parts are worth something so don't forget to save them...
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          Always..... Only thing i really bin is the pannel. I always keep all the boards,
            And you can always have fun with the panels...
            https://www.youtube.com/watch?v=mkvQ9aWM0DE
            • Easky15
              • Sep 2013
              • 285
              • Ireland
              Nice.... I've a few old microwave transformers lyin about left over from the spot welder build, Ill definitely be trying this.. ;-)
                Make sure to video it and post it on the tube!
                Or you could try "plasma suicide by overheating" - remove the heatsink from the bottom address board and watch the panel nuke itself slowly (bonus points for doing it on running video)
                • Easky15
                  • Sep 2013
                  • 285
                  • Ireland
                  I'll do it now.. ;-)
                  Which heatsinks should i remove..??
                  https://lh4.googleusercontent.com/-i...218_195305.jpg
                  Usually I come on here trying to fix TVs, Now I'm getting taught how to blow them up. :-)
                    Under the speakers. Runs along the bottom. Long heatsink usually screwed down. Prepare for crackles and sparks from the display as lines burn in permanently... but it's a fair showoff for a junky Samsung panel! (All the boards will survive this except E/F buffer along the bottom but that's usually bonded to the panel anyway.)
                    • Easky15
                      • Sep 2013
                      • 285
                      • Ireland
                      Have a look and see if ive removed the correct ones then ill fire it up and start recording.. ;-)
                      https://lh5.googleusercontent.com/-Y...218_201524.jpg
                        That's the one. Put a video playing on it, or something.
                        Apparently Freakaftr8 did this and his lasted a few minutes before things started popping..
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Oh this will be fun!
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            For an added bonus apply heat. Haha
                            • Easky15
                              • Sep 2013
                              • 285
                              • Ireland
                              Here goes..
                              If yous dont hear back from me after this phone 999... ;-)
                              • Easky15
                                • Sep 2013
                                • 285
                                • Ireland
                                Been on 15 mins now and nothing is happening? Is it just the metal bars or do i need to remove something else?
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Longer. Things for me started to smell at 20 mins. Noticed things happen at 30 mins. Total failure in 40 mins.
                                  • Easky15
                                    • Sep 2013
                                    • 285
                                    • Ireland
                                    Ahh right ok, I'll try again then.. ;-)
                                      How's it going? Burnt out yet?
                                      • Easky15
                                        • Sep 2013
                                        • 285
                                        • Ireland
                                        nothin still.... 4gb worth of video recorded....
                                        • noipi
                                          samsung Oled 65 Horizontal Lines and Flicker
                                          by noipi
                                          I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                                          10-14-2025, 02:11 AM
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
                                        • Rubenlily
                                          Samsung QE50Q67TAU - horizontal lines
                                          by Rubenlily
                                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                          I'm no expert but I've done the tape...
                                          08-16-2023, 01:12 PM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                          by x_orange90_x
                                          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                          09-04-2023, 12:09 PM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
